i really like mobile view.
i like the fact it takes you to your last read post.
if you want to go straight to the end, hit the reply button and make a post.
although, iirc back far enough, the old mobile version had go to last arrows.
and i dont know wtf tapatalk is....
So we are now on tapatalk. But we also have our own sau app built on tapatalk and its free! Android is available now, iPhone one is awaiting review so this week hopefully.
I've been using Tapatalk for a few days now.
Can't find a fault with it at all really. Works better than the standard IPB mobile skin.
Only thing is the Ads (but then it's a free app, so ye...). No doubt Christian will launch when the Apple part comes through as well.
How good us this? Viewing the forum on my phone via Tapatalk! Thanks so much guys! Awesome! Sent from my HTC One XL using Tapatalk 2
Yep and don't forget to try the SAU Community stand alone app too.
  • 3 weeks later...
Tapatalk posts seem to have some formatting issues...
Posts coming from it are getting <br /> 's placed as text within the post instead of a proper new line.
eg.
http://www.skylinesaustralia.com/forums/topic/421979-certified-100mm/?p=6802731
    • Yes to both! Yes to standard ECU and tune, but exhaust is aftermarket. Unsure on brand. Actually have it sitting in at my desk haha! I have to set it up on my laptop but this is a great next step, will do. So I generally try to shift before 4.5K RPM most times. I largely don't do a lot of high-rev driving, but I will take it up to red 1-2x a week max, as I know the occasional "Italian tune-up" is good for these cars.  Oh wow, is this way better than what I'm getting. Does this mean there's a good chance I have an issue?   Thanks for all the info so far guys.
    • Old Son, did you re-use the Holden ABS in the new shell or try a different module?
    • Yeah, nah. I had the actuator rod off it today. The arm will not move at all. Neither out, nor in. Yeah, you'd think so, but I've been thinking about that. Even when the actuator rod fell all the way off at the beginning of this saga, it would build more boost and faster in lower gears than it would in higher gears, and you'd think that that was the opposite of what should happen. But I strongly suspect that there is a thing with the gearing getting the revs to rise faster, that there must be some transient effect with the gas flow rate rising quickly, that you don't get with the more steady state case of the higher gears. Keep in mind - the gate is not shut in either of my weirdnesses. So things are not "normal". We normally think about a turbo spooling up (below the wastegate target) with the gate shut. I have all sorts of mental models running now where the gate is a little bit open, and having it stuck open allowing gas out while it should be going through the turbine has all sorts of weird effects (in these mental models). I'm thinking in the higher gears, the ex mani pressure builds to the point where enough gases spill out the wastegate to just prevent the pressure rising much more at all, or just creeping up, all the whole the revs are increasing and getting closer to the point where a gear shift becomes necessary.
    • Is it possibly wastegate actuator itself is sticking, or even the rod to flapper? Otherwise I reckon things are getting a bit rusty/worn   Also odd it won't boost in 3rd to 5th, but will in 1st, I'd expect the other way around with it slightly open as there's more time on your way to redline for it to spin up
