HEY ALL
TRYING TO DECIDE IF I WANT TO SELL MY CAR AS A WHOLE OR PULL HER DOWN AND SELL HER IN PEICES? ONLY SELLING DUE TO OTHER COMMITMENTS.
JUST WANT TO GET A FEEL FOR WHAT PEOPLE WANT AND IF I GET ENOUGH INTEREST IN PULLING HER APART THEN I WILL. IF NOT THEN ILL SELL HER COMPLETE.
OH AND SORRY FOR THE CAPS , FOR SOME REASON IT WONT ALLOW ME TO WRITE IN ANYTHING OTHER THEN CAP LETTERS? ( GOTTA LOVE TECHNOLOGY )
ITEM : TURBO KIT
GENUINE HKS 25/30 ( LESS THEN 3000KM ON TURBO, NO PLAY AT ALL )
GENUINE HKS SERIES 2 DUMP ( LARGER WASTEGATE PIPE )
GENUINE HKS ACCUATOR
XSPEED JAPAN STAINLESS LOW MOUNT EXHAUST MANIFOLD
ALL FITTINGS AND LINES
THIS KIT MADE 270RWKW AND 840NM OF TORQUE ON MY BUILT RB24
AWESOME SETUP , INSTANT RESPONSE
PRICE - $2500.00
ITEM : BUILT RB24
ENGINE HAS JUST BEEN RUN IN WITH THE ABOVE TURBO KIT AND IS A ANIMAL!!
BOTTOM END IS BRAND NEW
SPEEDLAB CUSTOM RB24 ( CUSTOM MACHINED R34 GTR CRANK )
GRUB SCREWED CRANK
LINISHED CRANK
EAGLE RODS
TOMEI PISTONS
ARP RACE SERIES STUDS
TOMEI RINGS
PISTONS HAVE BEEN TEFLON COATED
FRESH LINE BORE AND HONE
ACL RACE SERIES MAIN AND ROD BEARINGS
CUSTOM SUMP BAFFLES WITH TRAP DOORS
CUSTOM 9L SUMP
N1 OIL PUMP
N1 WATER PUMP
CUSTOM HKS 1.2MM HEAD GASKET
THIS BOTTOM END HAS BEEN MADE TO STAND BIG HP AND BIG RPM. ONLY TOP QUALITY PARTS FROM JAPAN, USED AND THE BEST MACHINING HAS BEEN DONE.
THIS BOTTOM END HAS COST ME BIG $$$
ENGINE ( HEAD )
FULL RACE PORTING
JUN 272 – 10.8mm LIFT ( BIG ) INLET AND EXHAUST CAMS
JJR ADJUSTABLE CAM GEARS
TOMEI SPRINGS
TOMEI BUCKETS
GREDDY TIMING BELT
CUSTOM OIL DRAIN MACHINED FROM THE BACK OF THE HEAD TO SUMP.
CUSTOM PAINTED ENGINE COVERS
THIS HEAD HAS HAD OVER $7K SPENT ON IT IN MACHINING AND PARTS FROM JAPAN.
THIS WOULD MAKE A GREAT STREET ENGINE OR TRACK ENGINE.
$7800.00
ITEM : FUEL SYSTEM
ALL THE BELOW ARE NEAR BRAND NEW, SHOULD SEE MID 300KW WITH THIS SETUP
SIEMENS 587cc INJECTORS TO SUIT GTR
HKS FUEL RAIL
TOP SECRET SARD FUEL REG
BOSCH 044
CUSTOM 6L SWIRL POT
$1200.00
ITEM : FRONT MOUNT
HUGE!
CUSTOM SPEED LAB FRONT MOUNT 600X320X130
CUSTOM ALLOY PIPING ( PIPING TO SUIT GTR PLENUM )
$1000,00
ITEM : CUSTOM GTR PLENUM FOR RB20
MUST HAVE FOR ANY ONE WITH A RB20!! ALOT OF HARD WORK WENT INTO THE MAKING OF THIS. SOUNDS AWESOME.
R33 GTR PLENUM
CUSTOM R33 GTR THROTTLE BODIES TO SUIT RB20
$1500.00
ITEM : ECU-COMPUTER
AUTRONIC SM4
CUSTOM RB LOOM
COMES WITH VDO SENSORS AND WARNING LEDS ( OIL PRESSURE AND FUEL PRESSURE )
CAN BE RE PROGRAMMED TO SUIT ANY APPLICATION, WAS TUNED AND AND MADE FOR ALL THE ABOVE ITEMS.
$1800.00
ITEM : WHEELS
R33 GTR WHEELS AND TYRES
IN OK CONDITION HAVE A COUPLE MARKS ON THEM
FRONT TYRES – 90%
REAR TYRES – 60%
BRIDGESTONE POTENZA
$850.00
ITEM : COIL OVERS
CUSCO COMP COIL OVERS TO SUIT R32 + OTHERS
GREAT COIL OVERS, HANDLING IS UNREAL AND SMOOTH
GREAT CONDITION, NO LEAKS
$1000.00
ITEM : DIFF
KAAZ 2 WAY
GTR DIFF COVER FOR EXTRA OIL AND COOLING
LOCKS UP LIKE YOU CANT BELIEVE
$850.00
ITEM : SEATS
R33 GTR FRONT SEATS
FIT IN 32 33 GTST
NO RIPS OR TEARS
$650.00
ITEM : CLUTCH
HKS TWIN PLATE CLUTCH AND FLYWHEEL TO SUIT RB20 BOX ( NOT SURE IF IT FITS OTHERS BUT THINK I WOULD )
LESS THEN 3000km ON IT
$1500.00
ITEM : N1 R32 HEAD LIGHTS
N1 HEAD LIGHTS, NO CRACKS
$450.00 PAIR
ITEM : R32 SHELL
I HAVE MY R32 GTST FOUR DOOR SHELL THAT HAS REGO UP FOR SALE INFO BELOW
SILVER, BODY IS A LITTLE RUFF BUT STILL PRITTY GOOD CONSIDERING ITS OVER 20 YEARS OLD
1989 MODEL
R32 GTR BRAKES AND SLOTTED ROTORS
HYDROLIC HAND BRAKE
ARC FRONT CASTER ARMS
CUSCO UPPER FRONT ARMS
CUSCO REAR UPPER ARMS
CEFIRO ENGINE X MEMBER ( ENGINE SITS LOWER THE STANDARD X MEMBER )
90% OF INTERIOR STILL THERE
99% OF ALL PANELS
HEAPS OF OTHER BITS AND PEICES
MINUS THE BELOW
NO ENGINE OR ENGINE RELATED PARTS
NO GEAR BOX
NO DIFF
NO ECU OR WIRING
NO SUSPENSION
NO WHEELS
NO HEAD LIGHTS
COUPLE OTHER SMALL BITS MISSING
$4000.00 INCLUDING REGO!
CONDITION : ALL ITEMS ARE IN GREAT CONDITION UNLESS OTHERWISE STATED
LOCATION : ALL ITEMS ARE IN ADELAIDE, POSTAGE AT BUYERS EXPENSE
CONTACT : PM ME
PICTURES : CAN MMS PEOPLE PICS
https://www.sau.com.au/forums/topic/340360-eoi-parts/
