Word of advice,
If youre going with a pod, buy a 3A brand filter... $30 at most and outperforms ALL big brand jap and local stuff in filtering ability and most in flow too. Usually sold at Motorquipe.
  • Replies 54
well..i went into villis tonight and it was uncomfortable to say the least.. i had no idea who i was looking for and the fact there were 30 pensioners behind me with an acoustic guitar frightened me. it was you guys wasn't it? thats why you drive wagons, to keep your guitars and walking frames handy..
but yeah, dissapointing :banana: i guess it was my own fault, it's disarming having a room full of peoples eyes glued to you and i was too afraid to ask someone, on the plus side i think i disturbed a few children.
anyway if it's a regular thing i'll come down next friday? i'm pretty easy to spot, a bandy legged kid with a funny hair cut and unsightly tats. so please say hi or at least tell me who to look for.
thanks guys
oooh. so it was you who was going back and forward in the white 34.
yeah... we were all sitting in the outdoor area.
hahahaha yeah that was me, made the mistake of looking for other skylines. mystery solved
There were a few skylines parked in the carpark/street, including 2 stageas :(
Drop in again this friday and say hi ya big girl :whistling:
i just switched from a Apexi power intake pod/with heatshield to stock airbox with K&N panel - seems to be slightly less hesitant and pulls just as hard/harder (definitely more quiet) so i might stick with the panel for a while!
do miss the induction sound from the pod already tho...oh well :down:
Not so sure Dave, I've been doing alot of reading into the arc airbox. They have no direct air flow to them so sucking hot air from the engine bay, there heavy so I'm thinking a well setup pod, heatshield and cai would be much better.
I'm a fan of people hooking up 1 or 2 plastic pipes from the bumper grille, into the standard airbox. Wouldn't mind seeing what happens then. Only colder air, less police attention in the engine bay.
theyre heavy? news to me.
ive got the 'lack of direct airflow' thing covered, a $5 cai from bunnings running from next to the passenger side foglight to the hole right in front of the airbox. problem solved.
just ditched my apexi pod for stock box and hi flow panel
sound = not so mean... but pulls better then a heat soaked pod
now to remake the intake snorkel into a wide mouth carbon fibre funnel and create headlight cover with flow direction into the snorkel ???
increase the lid top intake velocity/flow by doubling the hole size and smooth/direct flow inside the box
this is what i found when i changed from twin pods to the stock air box on the GTR, i noticed straight away that the car kept pulling hard right high into the revs, with the pods on it seemed to feel like it would hiss and make induction noise but then the power would trail off as all its sucking in is hot air.
i did miss the suction noise so i put the pods back on, but the loss in power because of the 'hot air intake' was not worth the sound.
on the GTR i have pulled that resonator thing out of the front bar, so running 16psi low and 21psi high boost i can hear the induction noise through that a little more.
seems like troy and i went from the same setup on the same cars back to the standard box! both had benefits...
+1 on your idea for the 'darth vader' of air intakes dude, anybody know anyone in adelaide who can custom make this sort of shit?
Yes. me
    • Any number of different ways. Have the coils draw sufficient current to provide contact wetting. Use different contacts in the switch, either by material or design, better suited to the low current drawn by a relay coil. Etc.
    • Hmm, how does the R34 manage to have headlight relays then without getting excessive carbon buildup on the headlight switch contacts?
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
