Kakimoto full mega n1 3.5 inch pipes with larger tip, metal cat looks to be about 5 inch body,
looking for $700 can organize freight at cost. prob looking at $50 or so via courier to most capital cities.
not willing to separate the cat yet.. but will consider
Whiteline strut bars and adjustable sway bars for r32 gtr, and maybe gtst?? $700 for the lot (rrp over $1000) front sway included (not in photo.)
Bilstein adjustable Coil overs with eibach springs front and rear $900 (photo is rears only)
Located in Sydney
I'm guessing the exhaust is more suited to track use due to the size? How loud is it really?
Its got a cat on it :blush: would be fine for the street, they sound very good
am pretty sure this is the same one
pretty quiet when you want it to be, and loud all the other times.
What spring rates are these ?
I'm not too sure on the rates. but heres the part numbers done thru google on the eibach website.
front and rear respectively.
Pm's replied to!
Exhaust and Cat now $700 including freight to anywhere in Aus!
Coilovers still available, and strut braces still available!
Exhaust is now 600 + freight in aus or pickup in Sydney
A decent cat is half that price!! this is a bargain!
When all else fails its going up on ebay!!!
hey mate if your intrested in seperating bars im keen on the rear sway bar
Hey they sold last week on ebay. sorry!
Shocks have sold on ebay.... someone could have bought and turned a tidy profit here!!
Still Have exhaust... 2 more days then its up on fleeeee bay too! unless someone takes it away now..
Genuine 3.5 ID on the exhaust?
I am unsure that even exists!! usually they measure exhaust from the OD..
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
