Hi All
I have many R34 GTR and GTT stuff to get rid of in my garage.
Here they are
R34 GTR OEM rims, 245 All around 70%+ thread remains, Absolute perfect conditions!. just some very minor minor scratchs. - $1900 firm
Nismo G-Max twin plate clutch with all the bits and flywheel bolts. 50-60% life left. flywheel surface machined for re-installation. - $ 500
R34 GTR starter motor, again mint condition - $200
R34 GT-T rear axials, hubs, hand brake and cables, suspension arms (top two are missing on the right hand side) - $200/left, $150/right, or 300 the lot
Stock R34 GT-T diff - $250
350Z Brembo's with 320mm diameter brake discs, fluid lines, brake pads with 70% life. brake booster kind of worn - $900 for the lot
R34 GTR front uprights, with hubs, brake dust cover and cut off axials. also speed sensor attached. one of the bolt on front left has been cut. - $180 left/$200 right
R34 GTR 2.5 lock-to-lock front steering rack. Perfect condition, no sight of wearing on ball bearings upgrade for Silvias/GT's? - $300
R34 GTR Alloy casted lower front A arm with bushings and brackets, Great condition Great for R32/R33 GTRs and GT's - $150/ea or $250/pair
R34 GTR stock front sway bar, great upgrade for other models - $200
R34 GTR front engine frame. Stiffer than older models - $300
R34 GTR stock engine mounts, locking nuts can be supplied if required - $ 100
R34 GTT rear sway bars same as Stock S15 - $100 each
R33/R32 GTR, R34 GTT Manual gearbox front cover and front main seal re-condition kit. $ 150
Oh.....also a bar fridge....great working order!....great for beers in backyard!!!! :P $30
That's it for now. Parts are located Melbourne East..
can organise freights for small-mid items. Pick up after hours or weekends. PLEASE CALL or SMS 0411 668 823, prefer SMS during working hours as i might be busy in work.
Pics below
Cheers.
Joe
Havent driven coppermix, so cant really comment on the differences.
This one is actually a modified version of exedy twins. But because it is spring loaded, it won't be a pig to drive. It holds up to 450-500kw? cant remember the figures. the coppermix is pretty much the same configuration and geometry as this clutch but with an improved material.
The brakes.. are they front only? Would they bolt straight up to R32 GTR?
Hi, it is confirmed. they bolt straight onto R34 GTR, there for they will fit ALL other skylines too. Also Silvias with extension bracket, they are probably the identical parts with the stock brembos.
Pics attached.
R34 GTR OEM rims, SOLD
R34 GTR starter motor SOLD
STILL UP FOR SALE
Nismo G-Max twin plate clutch - PRICE DROPED, $460, JUST THE FLYWHEEL IS WORTH THIS MUCH.
R34 GT-T rear axials - PRICE DROPED - $1500/left, $100/right, or 200 the lot
Stock R34 GT-T diff - PRICE DROPPED - $200
R34 GTR Brembo's - PRICE DROPED $820 for the lot, FIRMED
R34 GTR front uprights - PRICE DROPPED - $120 left/$150 right
R34 GTR front steering rack. - PRICE DROPPED - $250
R34 GTR Alloy casted lower front A arm -PRICE DROPPED - $100/ea or $180/pair
R34 GTR stock front sway bar, -PRICE DROPPED - $150
R34 GTR front engine frame. -PRICE DROPPED - $300
R34 GTR stock engine mounts, -PRICE DROPED - $ 80
R34 GTT rear sway bars - PRICE DROPPED - $70 each
R33/R32 GTR, R34 GTT Manual gearboxkit. - PRICE DROPPED - $ 120
AND THE BAR BRIDGE!!!! PRICE DROPPED - $20
PLEASE TAKE THEM OFF MY GARAGE!! :D
GTR engine mounts sold- pending payment
STILL UP FOR SALE
PLEASE TAKE THEM OFF MY GARAGE!! :P
Rims Sold
Clutch Sold
Starter Motor Sold
Engine Mount Sold- Pending Payment still. PM if you want the Mounts.
Still up for sale:
GTR Brembos
GTR Front suspension Bits and Stearing Arm
GTT rear suspension bits
Any idea if they would fit S2 stagea?
bump
STILL UP FOR SALE
The R34 and Z33 front calipers are identical.
To fit either front caliper to an R33/32 S13/14/15 you need to either have a thread insert put into the caliper to reduce the size of the thread by 2mm or drill out the knuckle on the car you're fitting them to.
  • 3 weeks later...
  • 1 month later...
Hi Joe, I am chasing a front left upright off a r34 gtr, would you still have it for sale and if so could it be posted and which bolt has been cut. Thanks Ian [email protected]
    • Let's hope that's not a copy pump either. There were so many copies of them back in the day.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
