Hi guys I have For Sale the following Items:
ER34 PowerFC $1300 used comes with box in Great Condition
HKS DragCoilovers Suit ER34 $1000 used comes with C spanners and allen keys(Brand New) Very Good Condition
Mickey Thompsons SemiSlicks 255 * 50 * 16 with R33rims $400 used about a dozen times in Very Good Condition
If theres any questions just PM me for more details...........
Will do a Package deal for the lot $2200 if anyone wants.
Regards
Edited by wrxxy
https://www.sau.com.au/forums/topic/340498-er34-parts/
  • Replies 49
Regards
Forgot to ask what are the the allen keys for? Do they lock the height adjusting rings or something?
https://www.sau.com.au/forums/topic/340498-er34-parts/#findComment-5511316
Probably lucky to do 1000-2000 klms as they are drag coilovers but perfect for street as they are not as hard as most coilovers outhere............
Edited by wrxxy
https://www.sau.com.au/forums/topic/340498-er34-parts/#findComment-5518779
