went out for an afternoon track session today at QR
have had the ME20 Pads in for 1 full and 3 half track days.
have been brutal on them the last 2 times out on the national circuit.
was about to head back out for the second afternoon session when a pair of black lines and some large 50c pieces of the pad material fell from the trailing edge of the backing plates of both front pads
The last inspection of the pads prior to the last half track day showed no cracking of the pad material and reasonable pad thickness.
https://www.sau.com.au/forums/topic/340512-brake-pads-disintegrating/
Endless W003 is the compound we use at Mallala - which is harder on brakes than QR - and no problems :D
Mark,
you've had a lot of rain up there recently, do you recall and instances where pads have bound to rotor (say overnight or if the car sits idle for a long period after rain?) you would hear/feel a noticable crack when you first move the car, or the car wouldnt move until you give it some throttle. I have a theory this happens a lot, and weakens the pad material, which then cakes off. Anyway, just a thought. I've never used ME20's, just the ccRG's (they have been fine).
Paul stokell diver training
I got a whole 15 min of drive time. :laugh:
Saw your car on the trialer heading out there! Looking very good :) It was the highlight of an otherwise pointless morning spent walking around in the bushes beside the cunniham highway lol
Saw your car on the trialer heading out there! Looking very good :D It was the highlight of an otherwise pointless morning spent walking around in the bushes beside the cunniham highway lol
So its you flashing passing motorists. :whistling:
How so Mark, Was there A lot of lecture time etc, or just too many peeps ?
Nah Noel I missed the first session as i was late from work and then the pads went after my first session out.
Didn't take a spare set of pads so called it a day.
Saw your car on the trialer heading out there! Looking very good It was the highlight of an otherwise pointless morning spent walking around in the bushes beside the cunniham highway lol
hope you weren't throwing rocks at it from one of the overpases!
Thanks,
Are u going to pirelli day on the 20th?
I might do those next year Drew. next track outings
- Lakeside 31st Oct (first time out there, really looking forward to it)
- QR 23rd Nov Round 6 Ruzic time attack series
Edited by handbrake
    • One thing I can tell you is, do it properly the first time. If you encounter unexpected problems just let the car sit for a week or two if you have to get some other parts or figure stuff out.  I'd have said go and use as many OEM parts as possible but since you want to change the turbo later on a custom kit is probably the better choice. Since I have no experience with RB25 just compare parts diagrams and images before buying a line kit and it should be easy to see if it has everything you need. Amayama has very good parts diagrams and part number lists, that is what I used a bunch to figure out what I might need. And don't forget to plan ahead and possibly renew other stuff that's easy to get to while you're in there doing the turbo lines. Happy wrenching
    • Update 4:   Hi all, good news. Engine is running and all the gaskets and seals seem to be working as intended. No leaks so far, even the JB Weld seems to hold. I flushed out the old coolant a few times and put in fresh coolant, not Nissan stuff, I decided to try the Ravenol Protect FL22, they claim it works for a wide variety of JDM cars and the opinions on it by some people were pretty good. And it has the nice poison green color! And man am I glad I bought a coolant system tester earlier this year, vacuum filling works wonders on this engine. I can definitely recommend this to anyone still doing it the old school way. All you need is compressed air supply. Will have to do a small test drive as soon as I can, I removed the gauge cluster again as the tacho needle was still bouncing around a bit but it was much better than before already.  I also found some cracks on all 4 tires inner and outer sidewalls. Apparently these tires should 't be parked on for extended periods or be kept under 0 degrees during storage, which I did not know. Clearly the previous owner didn't look into those details either, he probably bought them just cause they are cool semi-slicks. I'm just wondering how tf I am supposed to reach 30-80 degree tire temperatures on the public road consistenly, these tires were never going to work for my use case. I'll probably order Continental SportContact7 ones as these are the best allround summer tire available right now and I don't think I'll need anything crazier for now. Do let me know if you have experience with various tires and which ones you recommend.
    • You have no idea how many goddamn boxes I received these past three months haha Most have been put to use by now though, luckily
    • Not going to pretend I didn't do a bit of junky work this time around, but mostly due to the fact that some things I am not willing to spend days fixing right now, like wiring. I try to do most things properly the first time around.
    • Regardless of neglect or incompetence, fixing either is tedious and annoying. Most of the neglect on my car is definitely rust. I hope I can at least pass inspections later on and they won't fail the car due to slightly corroded hardlines. I was generous with rust converter and wax and it looks ok, most lines in the rear are hard to see properly anyways.  Definitely will test them though to make sure they don't rupture under pressure, in that case the car isn't going anywhere this year.
