I'm doing a big build, and just asking your advice one do i really need to have all the other stuff connected to the Balance tube? as i'm no longer running AAC, can i just loop the AAC back into the manifold, so that all throttle bodies are balanced, in my build ive got no need for half the vac lines, and i was just looping them into each other anyway.
has anyone pulled it all out before?
any opinions would be appreciated
https://www.sau.com.au/forums/topic/340532-rb26-balance-tubes/
i've stripped out all that stuff, is the balance tube the thicker one that sits under the plenum? i've removed my AAC valve too, so just ran some pipe from one tube to the other. works for me, i'm running a microtech which doesn't have AAC valve control too, hence why i got rid of it (weight reduction!). no idle control issues or any problems really.
id like to know the answer to this question also. i think the one under the plenum is the water bypass tube. balance tube is the vacuum tube and im pretty sure u will need this ?? im just running the brake and clutch booster straight to the 2 vacuum tubes that come out under the plenum.
