Have some A050's in Medium compound for sale. They are 255/40/17 all round.
They have done two track days, one at Eastern Creek, the other at Wakefield.
Current wear is:
2x80%
1x90%
1x60%
Looking for $1000 for the 4 of them which I think is dirt cheap since they are 2k new.
Contact: via PM
James
https://www.sau.com.au/forums/topic/340545-advan-a050s-2554017-x-4/
Here you are. (can't be bothered logging out from Matts account)
As you know, A050's just like most R comps have 4.8mm tread when they are brand new so when they hit the indicators they are only just under 50%.
http://picasaweb.google.com/lh/photo/od4aJ...feat=directlink
http://picasaweb.google.com/lh/photo/EaP5i...feat=directlink
http://picasaweb.google.com/lh/photo/YqAJh...feat=directlink
http://picasaweb.google.com/lh/photo/YCOqp...feat=directlink
http://picasaweb.google.com/lh/photo/_vgtl...feat=directlink
http://picasaweb.google.com/lh/photo/4Hj3g...feat=directlink
Edited by boxheadmr
  • 4 weeks later...
  • 3 weeks later...
Come on guys... surely you want to grab yourself a christmas present to make you go faster in the new year. I can't believe I can't sell them at this price they are dirt cheap!
Price reduced to 800 not negotiable.
  • 3 weeks later...
    • I agree re not trusting it as it makes mistakes however can do hours of research for you at times by simply asking a question
    • The I've done a lot of research and feel like I'm becoming a nut and washer expert. The washer in question doesn’t look very conical—it’s almost flat, but one side has a chamfer. The guide's picture shows the convex side (chamfered side) facing the nut, but the text says the chamfer should face the pulley, which is confusing. If I follow the picture, the chamfer faces the nut, but the instructions say the opposite. When I place the washer on a flat surface, one side looks flatter—maybe that's the concave side—so I would expect the chamfer to be on that side. But it isn’t, which adds to the confusion. The term chamfer is also throwing me off. I always thought the concave side should face the pulley, and the convex side (with the chamfer) should face the nut or bolt head. But Nissan’s instructions say the chamfer should face the pulley, which seems backward. I know I’m probably overthinking it, but I want to be sure I’m doing it right. Also, I’ve seen some people replace the nut and stud with a bolt, but I assume that’s not a good idea, since it might not keep proper tension on the tensioner. Lastly, just to be 100% sure: the pressure washer should face the pulley, then the conical washer? That feels strange, since usually the pressure washer goes first, facing the bolt or nut.
    • I checked, i dont think it was the indicator stalk. The problem just magically fixed itself though.
    • H1 is not the Humvee, but is the most road based version. Lachlan (HankScorpio) on here has a proper Humvee. He imported it a few years back.
    • Welcome Thomas! Sounds like you've made some progress. Are you able to drive it and enjoy it a bit now ?
