I was wondering how i could get hold of some r32 rear quarters preferably that have been cut off the car. They are to be used on a silvia to replace the silvia ones as they are wider and its an easy way to make a steel widebody for the rear of the silvia so i can get 17x10's under it!! Any ppl that would know speak up cause most of the importers dont bring them in:uh-huh:
https://www.sau.com.au/forums/topic/3406-r32-rear-quarters/
I was able to get them, as you are able to get 9's under the rear of a silvia, it's not worth spending that kind of money just to get one more inch, I would just go for a f/glass wide body, about the same price, and would be wider most likey.
my .02cents
https://www.sau.com.au/forums/topic/3406-r32-rear-quarters/#findComment-59338
can u still get them say aroun january cause iv already blown the money for them but i will still nedd them so ill keep in touch. Nah all steel is the way to go and its atually easier and far less time consuming if you know what you are doin, plus the arch diameter on a r32 and silvia are nearly the same!! also glass is dead wieght at least steel is real!!
https://www.sau.com.au/forums/topic/3406-r32-rear-quarters/#findComment-59876
GTS would do but if someone had gtr panels at the right price id be very keen, im in Canberra dude but will up your way in January which is when im now keen to buy anyway let me know! What do you have on offer!!
https://www.sau.com.au/forums/topic/3406-r32-rear-quarters/#findComment-60312
yeah i will its not for a while yet like mid next year but it will be in zoom cause im doin alot of other stuff to but i cant say yet its still hush hush:uh-huh:
https://www.sau.com.au/forums/topic/3406-r32-rear-quarters/#findComment-61604
    • Probably a smart choice to buy one vs build, purely for the motivation part as you said! Imagine the metal dust everywhere from grinding all the steel to build one. Ha ha ha!   Also, post a photo of your garage.   Mine is below, this is where I've been cleaning and have already half filled a caged 6*4 trailer. And this is after my cleaning expedition mentioned previously... The middle normally has a car in it, but I'm dumping things in the middle as I sort through them. And poor skyline was dusty and has had the lightest few drops of rain and now it looks atrocious and needs to be dragged back out and washed thoroughly! And yes to the right is technically another bay, you really can only see 2 bays out of 3 in this picture.
    • It's more like on average the things I see a lot of things going wrong. Yes, usually the people who reach out are the ones who are having problems but on average it feels like mechanics and tuners here aren't really competent. I swing between thinking my standards are just way too high and wondering whether people really are just this dumb. I just had the strangest 10+ reply argument on a Facebook group over someone insisting that the factory R34 GTT boost control solenoid reduces boost pressure to 5 psi when it's on and raises boost pressure to 7 psi when it's off despite showing the exact plumbing in the factory service manual and the solenoid behavior detailed in the FSM.
    • I steam cleaned my near new set of volk gtc wheels 14 years ago and farrkkked them lol. The clear coat cracked like spider webbing in several areas. Lesson learnt don't do that. 😭
    • If you don't touch the CAS, then you're fine.
    • Yeah, my moulds and seals are 32 years old now. I think I will continue to not use a pressure washer on it.
