wassup everyone , i kinda have a shell fs that i went 1/2s in with a mate a good 12 months ago with plans to make it into a race car , it was crashed but only superficial damage (only light panel damage) , the panels have been taken off for inspection and the car has had everything checked for straightness (it's all good) , things missing are: driveline, front guard, bonnet , front bar (rio is still there), front seats and that's about it , its had the front and rear subframes pulled out as i was going to modify/strengthen them but havent gotten around to it. I'm not in any rush to sell so if interested please reply in here . p.s it is complianced and not on wovr (title is clear)
also i will soon have a s3 r31 wagon for sale missing gearbox conversion (it was manual but i took that) and s3 front (has s1/2 ti front) comes with auto gearbox for who ever to fit , ran out of rego on the 9th of sep still in 3 mth thingy, has a rattle in the engine that i suspect is a lifter or cam bearing but was told it could possibly be big end , may wreck , white with blue trim $300?
Edited by toffy
https://www.sau.com.au/forums/topic/340610-eoifs-r32-shell/
  • 1 month later...
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
    • Silly question, as I bet you've checked already, but the motor turns over by hand yes? I suspect Neil has a spare starter, though if not, I believe I have a spare R33 (or two) starter.
