gday my names blake and i am looking to swap my ba xr6 turbo for prefferably an r32 gtr with similar mods/value or anything japanese for that matter. location isnt much of a worry for me aslong as you are willing to meet halfway etc.
i am a mechanic by trade and have installed all parts/done all the work myself (to a high standard)
Car: BA xr6 turbo 387rwkw, 72000ks 4spd auto
Price: 26000ono, swaps encouraged
contact: blake on 0418197241 or email [email protected]
Modifications are as follows:
rapidsystems stage 4.5 kit wich includes:
plazmaman plenum
big intercooler
2.5" hotside piping
3" coldside piping
plazmaman 4" intake
oddysey drycell battery
custom painted "stealth" look by myself
"tunehouse" exhuast:
4" dump pipe
5" cat
4" mid section wich tapers down to 3.5"
twin 2.5" tips
all stainless steel
"tunehouse" injectors (high flowed factory 800cc)
"atomic" flex plate
"atomic" valve springs
"process west" surge tank with bosch 044
"process west" rocker cover garnish
12lb wastegate actuator
ported wastegate 38mm
auto cooler
ecu cover
alloy overflow bottle
82c thermostat
turbosmart bov plumbed back
dba4000s
ebc green pads
braided lines
both front and rear
ford "idesign" interior wich includes factory optioned leather/seude seats dual zone climate control premium sound etc
vehicle is very well maintained
car has run a best time of 11.68@122mph down the 1/4 on street tyres, makes 387rwkw and 956nm of torque!
some photos can be found here:photos of XRT11S
if you are interested please dont hesitate to contact me for more pics/info
cheers Blake
https://www.sau.com.au/forums/topic/340613-387rwkw-xr6-turbo/
has it got a built bottom end? i would assume it does to be supporting those numbers as a stock ba bottom end would either be a hand grenade or unlikely making that power. either way would be good to mention if the bottom end is built as it would interest alot of people.
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
