Hi Every one, Im selling my GTR R34 Vspec for the first time, this wont come up again so I don't want dreamers or tyre kickers ringing me.
This car has everything with a list a mile long, I have spent over $150,000 on parts alone some you cant even buy any more to make this the best GTR R34 in the country.
I have got all the receipts and the work was carried out by the best in Australia, engine is standard bore 2.6 LTR and makes 510 KW with Dyno sheet at All 4 wheels below is listed just a small version of the work done.
Brand new N1 block
Brand new crank prepped
Tomei main studs and head studs
Tomei rods
Tomei rod bolts
CP pistons
Oversized Gudgeon pins
ACL race series bearings
Tomei oil pump
Hi Octane race sump with swing baffles
ATI 1000 hp balancer
Ferrera oversize stainless valves
Tomei Camshafts 10.8 lift and Tomei shim kit
Ported and flowed head work.
Hypertune custom made intake manifold and throttle body
Custom made mandrell bent intake pipe kit and the biggest Greddy Intercooler you can fit
T88 34D Greddy Turbo with ceramic coated housing and 4" dump pipe
Nismo Aluminium radiator
Aquamist water methanol injection
4" mandrell bent Stainless exhaust system
Holinger sequential gearbox brand new with Tomei shifter and shift indicator
PST 2000 hp carbon drive shaft
Ohlins Flag R coil overs custom made
Project Mu 360 mm front SCR rotors and 6 spot calipers carbon brake pads and spares
Project mu 325mm rear SCR and billet calipers
NPC billet custom clutch and crank trigger flywheel
Ikeya formula adjustable rear suspension arms
PMC surge tank with 2 x 044 bosch pumps -12 fuel lines and speed flo fittings
Rays 57F Prolight 18 x 10 rims and Pirelli P Zero tyres
Genuine nissan Vspec 2 carbon fibre bonnet with original bonnet.
Nismo white dash
Nismo MFD upgrade kit
Nismo Titanium front strut brace
Autronic SM4 with CDI with low/high boost mapping.
Genuine Nismo front bar with original one to go with the car
HKS 23 row oil cooler
PMC custom catch can
Car has been major project and is a absolute great car to drive, am moving onto something else so this is a one time opportunity to own some thing special. HPI wanted to do a feature on it but I declined, paint work is showroom not a mark or scratch on it.
Car comes with a heap of spares including Getrag 6 speed gearbox and transfer case with full PPG gear set and billet selectors, original rear drive shaft, spare Xenon head lights and a heap of other bits.
Price is $140,000 includes everything. Phone Dave on 0412 950192. I will supply all the documentation with the list of parts with invoices and all the work done. I have a lot more photos for the genuine buyer.
Edited by SkylineSky
https://www.sau.com.au/forums/topic/340632-ultimate-gtr-r34-in-australia/
  • 1 month later...
Update on the car, I have had lots of enquiries however only serious were nil....
I have sold the spare gearbox and other parts so the car is now $119,000 with the Holinger.
Give me a call on 0412 950192 if your serious.
Thanks Ben, how are you mate... will be down next month and catch up... Will be a sad day to see the beast go to someone else but have got some thing else on the go..
Will refund the airfare to a genuine buyer.. You wont be disappointed..
Going great thanks buddy! :(
I think you'll regret selling, but I guess we always do at some stage! Nothings forever :)
Make sure we get together for a brew or three when you're down!
Brand new N1 block
Tomei rods
Tomei rod bolts
CP pistons
Tomei oil pump
Nismo white dash
Price is now $119,000 as I have sold the other gearbox and other parts.. This is a bargain for this car...
Guest
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
