So i'm looking into buying some lenso D1R's, and not completely sure what colour to get, as well as offsets, etc. My r34 gtt is black with an impul kit (see pictures below) , and will be getting smoked indicators all round fairly soon unless you think clear might suit this set up better? I got my brother to do a really quick photoshop job on a picture of the car to give some sort of idea as to what they will look like in both black w/ red line, and aluminium w/ polished lip. Personally i'm heading towards the aluminium look with smoked indicators, but that's where i'd appreciate some constructive comments (none of the usual "oh they're bad rims anyway" "they're heavy" etc etc.) They will be street wheels, not for the track, so therefore i dont mind if they have a bit of weight or arent built to the same quality as some proper jap wheels. The size and offsets of rims, as well as tyre sizes i'm looking into running are 18x9 +12 225/40/18 (front), 18x10 +22 255/35/18 (rear). Would these be the best size to fit? I looked in the R34 Picture thread and "SiNNO" is running this setup, so i know it can be done, but my car is sitting a bit lower than his, so i might need a bit of camber? Is this the most aggressive setup I should run? These photoshopped pics give no justice to the amount of dish there would be, especially at the rears. :) Couldnt get pics to sit in here from photobucket, so have to upload them the crap way :) .
https://www.sau.com.au/forums/topic/340645-new-rims-on-34-gtt/
not a fan of the wheels at all but if i had to choose id say go the black and f**k off the red line....
I see where you're coming from, but i'm only looking into getting them because they are a cheap wheel with good dish. Not looking to spend a large amount of money at the moment to get some volk/work/gram lights.
So i'm looking into buying some lenso D1R's, and not completely sure what colour to get, as well as offsets, etc. My r34 gtt is black with an impul kit (see pictures below) , and will be getting smoked indicators all round fairly soon unless you think clear might suit this set up better? I got my brother to do a really quick photoshop job on a picture of the car to give some sort of idea as to what they will look like in both black w/ red line, and aluminium w/ polished lip. Personally i'm heading towards the aluminium look with smoked indicators, but that's where i'd appreciate some constructive comments (none of the usual "oh they're bad rims anyway" "they're heavy" etc etc.) They will be street wheels, not for the track, so therefore i dont mind if they have a bit of weight or arent built to the same quality as some proper jap wheels. The size and offsets of rims, as well as tyre sizes i'm looking into running are 18x9 +12 225/40/18 (front), 18x10 +22 255/35/18 (rear). Would these be the best size to fit? I looked in the R34 Picture thread and "SiNNO" is running this setup, so i know it can be done, but my car is sitting a bit lower than his, so i might need a bit of camber? Is this the most aggressive setup I should run? These photoshopped pics give no justice to the amount of dish there would be, especially at the rears. :) Couldnt get pics to sit in here from photobucket, so have to upload them the crap way :P .
hey mate,
definately would go for the black hweels and the smoked Nismo indicators and front lamps.
They'll look tuff! The black D1Rs won 'Best Wheels Award' at last year's R34 GT-R 10th Anniversary.
That doesn't say much for the people voting or the wheels that were there. I hope it's just clueless people voting for Chinese wheels over multi-thousand dollar lightweight race wheels.
Contact Jesse direct on [email protected]
You won't find service like him anywhere else and the prices will kill anything locally.
    • Oh, that's grim. Something bad has been happening there.
    • Put an endoscope down the hole and saw this. Not quite all around the bore but a good 60% at least. Chin to the chest and towards further disappointments I guess.
    • 2 does "sort of" applies, maybe......but looking at what parts would be needed for the swap to get engineered, registered, and insured, and basically that's everything under the car, the modifications the make it legal would be problematic and horrendously expensive, all for a street car that just cruises around and hits a few twisty roads on the weekends Also, from looking at the NSW rules and Regs, with all modifications that is required just to make the car safe and not twist itself to pieces, and then actually get registered for street use, may still be impossible nowadays As for 1, when you add in a fresh engine, fresh transmission, rear cradle and diff, tailshaft, suspension, brakes, cooling, and all the other fabrication required, your probably looking at up to $100k to do it right, all for a 20 year old MX5 that is over engineered and you would never be able to actually use the power it has on the street, much like your beastie, which I love, but you actually track that thing and can use all of its powers in anger, in a safe environment  Hell, the old Bogan Cruise Ship had more power than I could use on the street, and in hindsight, I went a bit silly on that thing, it didn't really need the 500hp it had for what I actually used the car for, it was fun, but basically unusable on the street if you value your licence  As for cams, yeah, I'll probably book it in for them to get installed and tuned soonish, like next month after MX5 Mania are back at work....... and yes, I've already sent a email to bin the turbo quote and quote instead to install cams and a new Fluidampr balancer that will suit the 2.5 better than the OEM 2.0 balancer that is swapped over for the 2.5 install, as the balancer needs to get pulled to time the cams it's a while your in there sort of thing I did think a bit about flex fuel for a laugh, but being na, and no where really around locally anymore to get E85, I've binned that idea, so no sweet sweet corn smells are set for the car I wish E85 was more of a standard fuel, it's better for the environment, better for tuning, plus that sweet sweet smell we all love As for fitting in the family, that's not needed, as everyone in the family already owns a car that can seat 5 humans comfortably enough, the MX5 is "my toy" As for buying a car that is already built, nah, I would rather pick and choose my parts, I enjoy the process, and in the big picture, the additional cost is well worth the enjoyment, and the occasional frustration, I get out of doing it, albeit with other people spinning the spanners, and me, just paying the invoice 🤣
    • Excuse me, but 2) does apply 1) Would also apply if you consider how much is spent in the alternatives. Also there's the option of 3), buy one pre-built that you can put your family in (it's me, it's my car)   That said, I went on a ~500km drive the other day. I didn't use anything more adventurous than 3rd/4th gear at about ~3000RPM and 50% throttle and I was going as fast as anyone has any sense doing on a public road, with enough grip to the point where I didn't want to go any faster. I was obviously under the limit of the current car etc etc. MX5 with 2.5 N/A to achieve the same speed would be more fun for any road scenario. Maybe consider cams. I wouldn't boost it. The use case is just not there and it won't actually make the car more enjoyable unless you really do plan on wringing gears from 1st to 3rd (at least) at 100% WOT on a public road to 150+kmh.
    • Great if: 1. You had all of the money for everything else that is required  2. Lived in a country where you could actually do this and drive it legally on the road Sadly, neither applies to me As for the turbo, I am having second thoughts, mainly for engineering/registration legality reasons and insurance  Not saying I've finished doing stupid things that I probably should do to the MX5, but boost, and V8 engine swaps isn't on the cards Strange, but true
