I got a Z32 ecu that has had the internal modifications done and chipped to suit a RB25DET - Series 1 or 2
This ecu only requires 1 harness modification to your loom, it also has a chip with a transfered RB25 map.
This ecu can be chip tuned by your tuner or you can install a type 2 nistune board inside it.
ECU includes EPROM that can be written / erased unlimted times - you can re-tune this ecu as many times as you need when you mod the car, unlike the R33 remaps where a new chip needs to be purchased
Tested working - selling for $400
Can post only, price includes post.
https://www.sau.com.au/forums/topic/340666-z32-ecu-modded-to-suit-rb25det/
hey.. did this take away or change any serise 2 r33 gtst features?.. everything works as it is meant to just like the stock ecu?>. i guess a 300zx has everything a r33 has :)..
hey. would you take 200 now and a r33 gtst fuel pump (done 66,000kms) and a series 2 stock r33 ecu.. it says remanufactured on it.. but may not have alot done..
what was this ecu tuned for?.. mods.. thanx
Hey.
Everything is working as it should with this ecu in RB25DET, it has been modified internally to suit. It even supports VCT as normal and it is fully tunable.
At the moment the ecu just has a base map inside it with Rich and retard and air flow cut removed, and speed limiter removed.
I am going to be tuning a series 2 with a 044 pump fmic and kkr480 turbo and full exhaust this week so I could put this tune inside the ecu for you if you wish.
It is recomended that you get the car fully dyno tuned when you buy this ecu, its fully programable so it will do the same job as a power fc or a ECU with nistune.
Not interesed in swaps sorry
cheers
hey.. did this take away or change any serise 2 r33 gtst features?.. everything works as it is meant to just like the stock ecu?>. i guess a 300zx has everything a r33 has :D..
damn.. i just bought a mines damn ecu for 250.... like yesterday at 5pm.. wasent sure what to do.. any didnt wanna miss it :).. this would of been sos much beta..
    • Is there a way to adjust all of the pedals in an R32 GTS-T? they all sit even, but seem to be a little high for my liking.
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
