Hey all,
I'm currently looking at getting a brushed aluminium dash (well the bit than runs from the handbrake around the stereo and across the wheel) manufactured to fit my gtst. I'm looking to get one made because so far i cant seem to find any aftermarket ones on the net.... ok let me correct that... any Real brushed aluminium replacements... just synthetic veneers.
It looks like the materials will be pretty cheap, and i'm chatting to a guy about getting them bent to shape (prolly use my current bit as the template... makes sense).
I was wondering if there was anyone who's had it done and can comment on it.
Now unless i hear any major horror stories i'm gonna go get one made up, and if all goes and anyone is interested i was looking to see if anyone else would be interested in getting one too.
The chap i'm off to see tells me he might be able to put a better price on it if i get a few instead of waisting materials with a one off.
'd look sweet with a good metal shifter too.
any takers?
https://www.sau.com.au/forums/topic/34067-brushed-aluminium-dash/
Import Scene
www.importscene.com or www.importscene.com.au (not sure which)
they are in WA though.. but they have tons of that sorta stuff, i remember seeing brushed aluminium dashes.. (they are synthetic though)
they are kinda complicated aren't they?..with many bends and folds and things. Would be hard to get one as good as the moulded plastic i'd imagine.. hence why they used plastic in the first place. If you could get a good one made up I'm sure you'd get a *hell* of a lot of people on this forum want to buy them though..
is that good or bad?? lol
it looked good when i was browsing them... now i'm not so sure... it could have meant veneer = wank.... or i wank over veneer, i'm siding with the first one.
i keep on getting flash's of the veneer peeling sometime
uurrrmm... i mean cos of moisture..... Damn i mean humidity.... from like... uurrmm crap.
i regret saying "i come over veneer"... everything i type seems skewed now.
it's gonne be a matter of either careful folding, or making a mold and pressing apparently.
If its a cash if folding then hey its prolly gonna be a lone custom job, but if its a mold job... then hey... why waist a good mold
I was thinking about something like that for an R32; though with the stuff black-anodised. You'd think that a metalwork shop could make a copy from Aluminium if you gave them the original plastic one, right?
yes they could, but be prepaired to pay for it!
The fake stuff will start to peal after awhile i recon and it will look shit
it would cost shitload to make one out of aluminium, not only do you have to make the aircon vent holes, but it has to curve around the stereo and dash ect, then you need to make the clips that hold it in place. if someone can make it i would be very suprised. brushed aluminium is also easy to scratch, but you can jsut sand it and it will look normal again.
if i was you i would go for a aluminium laminex version that is accually made for the car. they are quite durable, i had a placecard thing for kitchen doors, and i tried scratching it ect and it was fairly strong.
also aluminium will heat up so quickly in the sun. my IMPUL gear knob shits me.
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
