hello, was doing some searching about exhaust manifolds on here, but got nothing i wanted to find.
my question is, im looking at replacing my original rb25det turbo manifold fomr the NEO engine,
since i want to keep original dump pipe etc, what manifold do i need??? my guess is low mount manifold, but will it all sit back the way it was????
im just looking at a bit better spool up and ive seen a couple of different manifolds which im interested in, just waiting to hear on the length of each cylinder pipe.
i will calculate what manifold is better for low down rpm.
so is the low manifold designed to keep stock stuff on???
i just dont want to sell my new downpipe to get one that fits the new manifold.
thanks
Jean
https://www.sau.com.au/forums/topic/340679-exhaust-manifolds/
i heard there is minimal to no gains to be made on the neo from aftermarket low mount manifold, if you was going highmount yes,
i have r34 gtt built motor, 3076, all supporting mods and stock manifold last dyno was 311rwkw with wheel spin (with amount of camber i have we couldnt eliminate the wheel spin) on 19psi
actually, just a quick question, this has been bugging me for a loong time.
the so called turbo manifolds and extractors, which would be more efficient at quick spooling????
the manifold or the extractor???
if you think of it theoretically, the spool time depends on how fast your exhaust gases can get to your turbo.
say the stock manifold is set up like this:
cylinder 1 is a 20cm pipe to turbo, cylinder 2 is a 6cm to turbo, cylinder 3 is also 6cm to turbo and cylinder 4 is 20cm to turbo.
that means the shortest exhaust gases will come from cylinder 2 and 3. to travel the 6cm, means short turbo spool or turbo lag.
while with a mandrel bent extractor, cylinder 1 will be 25cm, cylinder 2 is 15cm, cylinder 3 is 15cm and cylinder 4 is 25cm. it means it will be able to get the engine to run more freely, but it does not guarantee a faster travel of the gases to the turbo, so higher up you should see a bigger increase in engine power, 15-30hp on a basic extractor. but therefore a bit longer turbo lag from the longer gas flow. gas travels 6cm in the manifold and 15cm in the extractors.
while this is not the case for NA cars since they dont need to run a turbo, they would benefit from it alot better.
so is this really the case when buying extractors???
would the turbo lag be increased but the overall power gain in the higher rpm???
well extractors is anything non original manifold basically, it extracts your gases, tuned length, manifold is just the basic crap you get on your stock car, NA or turbo. well from my view at least.
but say you popped a t45 or t66 on there, a top mount, that should kick your lag in to well over 4k rpm.
You have one manifold - It's being forced out, not extracted.
There is a difference.
A stock RB25 manifold seems to be good for around 300rwkw.
I remember back when Joel (Cubes) and others were playing around with a 25/30, 300rwkw of flow seemed to be about the limit airflow wise with some gains had by changing.
So that said, anything 300rwkw or less - spend the money elsewhere.
That pretty much covers off 99/100 set-ups nicely. And the cost of a good manifold is basically a full car of pad/rotor/fluid/lines in terms of a brake upgrade... Something you will notice a lot more :worship:
There was a table of test results for manifolds kicking around. I think it was bench flowed results, it would be a bit dated now, but it was good because it had back to back tests in it.
The HKS cast low mount came out best overall, but I'm sure some of the well built ones like 6boost etc would be just as good these days [not sure if they were around when the tests were done?]
If you searched you could probably still find it, think it was on a UK site but may have been an NZ test?
    • Is there a shroud around the tailshaft spline into the back of the box? They can rub and make a horrible noise if they are not on straight/damaged. The heat might have caused it to grow too much in one direction and rub.
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
    • I would like more noise related info for my truly uneducated guess  Does it do it at idle or when revving, clutch engaged, and disengaged? Does it only do it when the car is moving? I've heard "similar" noises from a clutch pack that left the chat room, and CV joints that have chewed themselves out But as Matt said, how's the yokes, tailshaft and centre bearing going after their last little issue Fingers crossed it is something simple  Weird noises make me cringe
    • One other question, is there a chance that changing the idle speed can lead you down a rabbit hole and is the reason the tuner didn't touch it? Reason I ask is because if that's the reason the tuner avoided it then I probably shouldn't be touching it lol.
