ok well i had my gtr off the road for about 2 months seeing it didnt have rego the car was running fine before hand but when i got my 32 gtr back on the road and rego paid etc it straight away had this stalling problem what happenes is when you give it a bit or get the revs higher maybe about 4 and a half to 5 and come to a stop when you put the clutch in the car just cuts out and stalls. i have been trying to find out the problem for a few months but cant figure it out i have bought a brand new battery and put that in and hasnt solved the problem. i should mention tho i think the turbos are a bit delayed so i think it is needing a tune could that be the reason? when im just cruising normally its fine and it only does it some days now and some days it doesnt i really need help with this so if someone could give me some hints to what it could be it would be greatly apreciated.
https://www.sau.com.au/forums/topic/340682-need-urgent-help/
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
