I have a problem I need fixed fairly quickly as Im driving to Kadina this afternoon.
My lights arent working for some reason. If I put full beam on the LH side will light up, nothing on the right.
If I put normal lights on nothing will come on . Basically nothing at all coming from the RH side.
I checked all fuses, this was my initial thought.
Surely it couldnt be the globes ? as all rh side lights arent working. relays ?
https://www.sau.com.au/forums/topic/340692-r34-lights/
i found it was the fuses in the car by the driver side doors, they did not look broken but i replaced them and the lights worked perfectly.
It is he cheapest and easiest option to start with
https://www.sau.com.au/forums/topic/340692-r34-lights/#findComment-5500927
