For Sale is my HR r32 skyline.
Car is running 10pound on road tune
When car was standard i had it dyno and made 240hp, with new setup it should make over 300hp.
Engine work:
GT30 with a .6 housing
6boost exhaust manifold
38mm turbosmart external wastegate with screamer
walbro 500hp fuel pump
600cc HKS injectors
Z32 airflow meter
Splitfire coilpacks
Apexi power FC computer
Extreme heavy duty clutch
Hybrid front mount intercooler
HKS super suquential blow off valve
Suspension:
HKS Super street coilovers all round
Brakes:
R33 GTST
Wheels:
Lenso LS5 19''
$13,500
If your interested do not hesitate to call me but please no time wasters Thanks
David - 0431023845
Edited by qu11kr r32
https://www.sau.com.au/forums/topic/340731-for-sale-hr-r32-gtst/
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
