Thanks to everyone who previously voted. I'm thru to the finals. You can vote online here http://www.totalcarmagazines.co.uk/idol-nissan-FINAL-2010.htm
There is also a link on that page to a pdf file with more pics and details.
I don't expect to win, but you never know, and it would be awesome to have a Stagea win it.
voted for yours, yours does look the best, but some of the 350z's and the r32gtr arent far behind, the s14 looks decent, but the body kit on it is a bit overkill, good luck with yours
Thanks guys. I've moved up from 11th to 7th now. Some great cars on there that deserve to win but here's hoping..
I'll be going Nistune, bigger injectors and a Z32, but I really need to do something with the exhaust drone, get some new sway bars and a valve body upgrade first.
Valve body upgrade? Manual conversion should be less than a thousand pounds!
I know what you mean. Problem is the amount of titanium plates and screws I fairly recently had put in my left ankle to hold it together. It's just as well that I quite like the tiptronic anyway.
    • Alright. Exhaust has been looked at, and booked in 'soon'. I'm not 100% convinced it's going to be as good as possible but I'm going to go with it anyway. If I get a reasonable thing that works for 10 years I mean that's twice as long as I've lived with the current one. I have a more pressing issue. I have fixed my MPVI3 (by buying a new one). Excellently, one can wire in analog 0-5v inputs to the ECU itself. I had wideband already via Serial so I also wired it in via the direct input. The idea being I can use the standalone logging without a laptop and have Wideband data in it. The other wire I thought I'd use oil temp. This is where I've gone crazy. HPTuners requires you to implement a formula so you know how much volts = how much temp. This seems relatively simple to me. However I cannot find the scale for this anywhere on the internet, nor decipher how to figure it out without removing the sensor from the car. All I know is that voltage actually goes up as temperature goes down. I am using the actual gauge, so I can see what the temp is. The signal wire has been branched off into the MPVI3. EXAMPLE: 2.68v = 58C 2.7 = 57C 2.74v = 56C 2.8V = 54C 3.06V = 49C 3.18V = 47C 3.37V = 43C I think the gauge is 50-150C. It may be more. It may be less, because I can't find it for the love of f**k. It appears all the information about the gauges I have has been scoured from the internet, but the sender is VDO 320.021 I believe the resistance chart is this How the f**k do I convert this to a voltage? Once I have a voltage... I then have to perform this transform of said voltage to show it in the scanner: https://www.hptuners.com/help/VCM-Scanner/Content/vcm_scanner/defining_a_transform.htm @GTSBoy you're probably my only hope here TEST YOUR MIGHT
    • Here’s the updated and installed muse replica nismo ones … very happy with the outcome. Eventhough I painted my whole rear end due to my rich idle lol.
    • Hmm. I had a good look (w/o searching, because I'm not logging in) and couldn't see it either. I distinctly recall the thread, not many weeks ago. It must have been removed or perhaps put into the back section. If it was in Off Topic you should at least have been able to search it up. So if I'm not hallucinating, it is fairly decently removed.
    • I had my car model wrong on my Shannons insurance when i had my V36. didn't make a difference when i claimed a windscreen. Nightcrawler is a negative nancey 🤪
