  • 4 weeks later...
  • Replies 70
i should probably post in here instead of the monthly photo threads...
third day working on the new bike, showoff fail! :P
and some other random stuff from the day
looking to get a better NLE than the iMovie that I am using. what suggestions do people have for something cheap but more powerful than iMovie?
cheers. the fish eye effect is due to the wide angle of view these GoPro cameras have. you have to frame shots by gut feeling or take a photo and then chuck the card in a camera so you can check framing, but as that takes too long most times i just wing it and hope for the best, lol.
as for the editing software, i'll continue on with imovie for now. its capable of some cool things, at a cost of plenty of hours work, lol.
A few of you know that I shoot a lot of video with a GoProHD. One thing that works well is not to worry about putting the camera upside down as you just correct it after shooting. That saves time at the track.
Here is the GoPro Tutorial including what free software to use. The software is also good if you just want to trim/cut but preserve 60fps. Not that many software programs support 60fps as it isn't a true standard.
http://gopro.com/support/rotate-stream-clip
New "Tilt Shift" effect video from the Texi
I'd say this would work better with a higher viewing angle. Doesnt seem to really convey the 'miniature' effect with such low camera angles I think. i tried a few tilt shift vids a while back and found the higher the angle the better it looked. im no pro tho, so i could be way wrong.
http://www.facebook.com/video/video.php?v=1472752651887
You are so correct Jay. It's really hard to get a high angle at the level ground we have on the Texi - and a ladder won't fit in my GTR :D
I was pleased with the effect on the silver gtst and with the on-car (was my GTR) - those had a nice "gee am I looking a toys" feel. Mainly I was playing with the new VideoStudio "Stop motion" effect and seeing what I could do with the footage I had.
Thanks for the tip!
i wish there was an easier way to do them on a mac. i pretty much split the video down into frames and then used a photoshop action to tilt shift all the frames as a batch. wasnt pretty, haha.
keen to see more tho, i just dont have the patience for stuff like that these days.
Wow that's a painful exercise. On the PC I use a filter by NewBlueFX - check their software out because the plugin works with lots of different programs. Rack Focus is in their Video Essentials II package. I'm just about to pull the trigger on their stabiliser package since I do so much work freehand. That stabiliser looks very intelligent in the way it works.
The filter is only about $100 and also gives you several other options - blur edges, etc.
  • 3 weeks later...
So this weekend I stumbled across this site when I was doing some research on DIY'n some gear. The site has a great mix of DIY and affordable gear review by normal Joe budget shooters like most of us.
I've spent literally days exporing the past articles and reviews. I've now also ordered some gear the I've been wanting but couldn't find cheaply enough or was worried about the quality.
http://cheesycam.com/
    • They need to get a grip. R32 GTRs got as low as AU$8-10K at one point here.
    • You have just offended every teenage boy in America
    • Structured text and other high level PLC programing languages are not allowable in Functional Safety. They are very difficult to audit. My PLC stuff is almost exclusively oriented towards Burner Management Systems which are a particularly pernicious form of Safety Instrumented System, when implemented in an SPLC. Even the part of the code written to work in the non-safety logic part of the PLC, like with a Siemens S7-1500 series, still needs to be treated as if it was safety code, with access restrictions, code fingreprints and the like. And Allen Bradley can go EABODs. They ae full of shit. They have this whole lie going on where they say if you use a ControlLogix controller and its IO, and then just duplicate the IOs (ie, run in series or parallel depending on type, to try to make it "fail safe") and "use these programming styles and place these restrictions on what you do" that you can achieve SIL2. What a load of crap. They just get away with it because no-one in the US seems to understand the first thing about Functional Safety and carries on as if all they have to do is buy only SIL2 rated equipment and hey presto, it's a SIL2 system. Idiots. /rant
    • If you're really considering leaving it, a great question to ask is, is the magnet going to stick to the sump? The answer to the above is the same answer towards if I'd have any level of comfort leaving it... Personally, based on the cost of a motor if the magnet were to cause damage, I'd be fishing it out either way. Use the methods in here. It fit in through the plug hole, it'll come out.   PS, get a small actuatable claw for a bore scope. OR if you know a vet, they have really cool controllable scopes with hooks on the end. Supposedly they're like playing a video game. Ask if they can acquire you one of their scopes... Engine oil after all is just a different type of lube right? Will only make it easier on the next dog or cat...
    • All other (Boolean) logic functions though, are just built on those blocks above. Which does give you a lot of functionality in logic. It is basing that on using thresholds with analogue signals like GTS alluded to.   Not having things like timers will make it less useful for some of the ramp up logic you'd want, and again, on Haltecs capacity specifically, I'm not across anymore what you can / can't do with different tables.   I'm assuming, with your logic you want to implement, not only do you want your timing safeties, you're wanting to be able to derive the duty cycle for your solenoid, to maintain I'm assuming 175PSi? Or are you using a standalone WMI controller to maintain the DC correct, and you just want the Haltech working out which fuelling maps you should be on?
