Seller states it's an AR-X in the title. I thought the AR-X had flared plastic wheel arches, 18" wheels and higher ride height. That one doesn't.
I see it's listed as an RS-250 Four further down.
I noticed that too.
always has me worried when the seller doesnt know what there selling however in the description of car says its an rs with ar-x interior so maybe just did it to get atention to that detail?
Me too, but the issue is that some car dealers are employed because they're enthusiasts themselves, and others are employed purely on the basis that they're good at selling cars. It's just like any other industry, but it's a shame that in some cases those in the know are not the ones writing/creating the ads with the correct information.
  • Replies 69
japlink looks interesting, pity only one on there i like hasn't been updated or is arriving next august :D i don't mind the look of http://www.nagoyamotors.com.au/zoom.php?id=1181
or http://www.allimports.com.au/view/detail.p...amp;car_id=1046
Sucks living in Canberra i know I'm gonna find a car i like, go for a trip to Sydney and be disappointed
Edited by Lucid-_-Stag
I don't have dual Climate control in mine... Another Stagea abnormality! Who knows... doesn't bother me!
edit- but i do have steering wheel controls for stereo and phone(!)
Same as above with my S2 M35 250RX FOUR, and the built-in bluetooth works well with my Nokia phone. However, some S2's don't have stereo/phone controls on the wheel. It seems you could specify just about anything you wanted when new.
fluffy dice...? :)
How did you get the bluetooth to work? I haven't tried it at all, just figured it wasn't worth the effort, but if it works, might as well hey?
fluffy dice...? :)
I got the bluetooth handsfree working by trial and error. Once you find the bluetooth menu, one of the options (in Japanese) is to search for BT devices. I enabled discovery on my phone, and it found a BT device named "MY-CAR". You then enter the password "0000" on the phone, and from then on, they'll connect every time you turn the ignition on. There's a MIC up there on the roof, and you can answer calls from the button on the steering wheel. Incoming calls mute the stereo. If you're in Japan, you can activate voice dialing to the "Car Wings" service and possibly other numbers using the "Voice" button on the wheel. Once the Jap to English translation's been done on the S2 screen, all this maybe easier to deal with.
Edited by Spong
LOL, don't you wish it could translate your conversations to Japanese too? Calls to Japan from a mobile might be expensive, but if it means ordering parts direct from Nissan Japan, it might work out better in the long run.
Wishful thinking...
when we say dual zone we mean there is a seperate temperature for the driver and passenger. your car has that?? if it does, i honestly didnt know it was an option. never seen it on an M35 before. and yes yours is a 'series 1'
cruise is a luxury that is very rare.
Alex, can i come watch??
Alright pretty set on getting an axis, GT High performance have one comming in with dual sunroofs soon :yes:
2 Quick newbish questions, 1st do the axis have a full autech exhaust or just mufler? (for dump pipe sakes) and also whats the little orange button under the glove box for :P
Turbo guys correct me if i'm mistaken, but generally the Autech models exhausts differ only in the muffler - thats what I've seen on the PM35's.
Orange( or red) under the glove box- thats probably a emergency road flare, the kind that go onto football pitches regularly. Jap car thing. Tell your mate its an ejector seat button if you have sunroofs.... :P
    • Hi again all, I’ve tried doing some searching on the topic but couldn’t find the answer I’m looking for.   I deleted my clutch booster because it had an air leak and was squealing like a hog, and now my clutch has very poor pedal feel and the friction zone is way too small, so I believe I need a bigger diameter clutch master cylinder to compensate for not using the booster. I found a Wilwood option that’s 3/4” for a good price and will fit my 3AN clutch line, but all the firewall adapters I see online such as RB factory or Chase Bays are listed as RWD only (GTST/GTS). Link below. https://rbfactory.shop/products/nissan-to-wilwood-girling-clutch-master-cylinder-adapter My question is if these adapters will also fit a GTR, and if anyone has experience using a 3/4” CMC without the booster, my clutch is a Nismo coppermix twin plate.   Thanks, always appreciate the advice!
    • Catching up on a post, I've replaced the external shark fin with a small 4g antenna (no further drilling, just a 1mm embiggening of the existing hole, and run that to where the dual battery models have the battery in the left rear guard.  No idea what the factory antenna did, but removing it had no impact on anything I use, according to the US manual the GPS antenna is in the dash and it still works fine Also ended up stealing battery power from one of the amps and ACC power from a unit nearby to add an ACC relay to power it. The mounted the booster, wifi, power socket and antenna splitter in the rear left guard out of the way, all out of site with the boot trims in
    • What drama? The only drama you're going to have is the near constant work to maintain all those sphericals. I only have sphericals in my front caster rods and front upper CAs (because both of these are near compulsory in an R32). I have had the front arms out of my car 34 times already this month, and if the new replacements arrive today, I will have them out and apart again tomorrow. Chasing clicking and clunking that comes from sphericals being a.....poor choice for a road car. Moisture and dirt are not their friends. I have been contemplating a change to my rear subframe that would require me to use sphericals in my lower CAs. And.....I don't want to have them that close to the road.
    • Did you need anything else you've already done? If you had it before... and liked the changes after, then supposedly it'd be more of the same. The idea about most suspension arms is to tune geometry that the OEM arms max out at/can't handle because they weren't designed to have the car setup in such a way that 'looks good'.
    • I have replaced everything on my r34 including suspension to Miester R, all rear subframe bushes to poly, all arms to metal adjustable and same in front.   only thing I haven't touched is the front lower control arm. Should I? what improvement can i expect ? I mean the one on the link below?   Car drives perfectly, it is just me thinking everything is either puly bush or hard bearing type so should also do lower control arm front but do I really need it ? https://www.japspeed.co.uk/product/suspension/adjustable-arms/nissan-200sx-s13-s14-s15-skyline-r32-r33-r34-adjustable-suspension-front-lower-control-arms/?gad_source=1&gclid=Cj0KCQiAo5u6BhDJARIsAAVoDWs5V_PauQPf0kx3zFCaA4tOC9Q7JSIsfJWma_jAPN2f1sJA686djOwaAidgEALw_wcB
