A31 Cefiro For Sale
Hey guys the time has come to sell my 1989 ceffy. Have owned the car for nearly 4 years as my daily and have done a few mods over the time. odo reads 198 000kms but not sure if they are chassis kms or what (has r32 rb20det). never really had a problem with it, serviced regularly needs a little tlc paint is ok has a dent in rear guard and small dents in front guards. car made 227rwkw at 18psi six months ago until then has ran standard turbo and boost. Its Regod for another 2 months looks clean and goes well looking for around $10200 ONO!!
Mods:
alarm and immobiliser
Manual (still 20 box in good nick little bit of noise)
Blitz K26 turbo
38mm external gate and screamer
440cc gtr injectors and impedence pack
6 month old walbro intank fuel pump
Z32 air flow meter
nisstune chipped computer
front mount
apexi filter
3 inch turbo back exhaust with high flow cat and jun bul muffler
nolethane g box mount
exeedy extra heavy duty button clutch
Brand new project mu hand break shoes
new rear break rotors
new pads all round
cusco front strut brace
d2 coilovers all round (fronts camber height and dampner adjustable, rears height and dampner)
isc castor rods
boost guage
turbo timer
momo wheel and knob
has shimmed lsd in it but have a 2 way aswell just a bit too clunky still works tho.
R32 gtr seat
Autech kit (front bar damaged has standard front bar atm)
aluminum rear subframe mounts
non hi cas rear
has 17 inch drift teks on it fronts are 8s with near 90% federal 595s rears are 9s with 80% stratas.
pioneer head unit 6 inches and rear 6 by 9s.
ph:
Thanks guys!
  • 3 weeks later...
  • 4 years later...
 Share
    • Nice write up solder thank you.  that problem had fallen into another days fun. I wanted to get this cold side in and turned over so it was wired up the same to get a start. no luck I got a couple of cough’s before the battery died unfortunately. we have some wether on the way and I’m back to work, I will order your plugs and re wire them in the near future. 🤙
    • It was simpler than that. Few things going on. One is that I hate plastic clutch alignment tools. Anybody who reads this in the future and is considering one, don't. Even for 3 USD it's not worth it. Mine left plastic shreds all over the inside of the clutch hub. Now I need a proper steel one and to re-grease the hub splines very carefully without leaving any excess that could go into the friction disk or anywhere else unintended. The second is that I'm bad at reading directions. There is a step in the instruction manual that tells you to put in the 3 M6 bolts BEFORE you attempt to put the clutch onto the flywheel which has been bolted to the crank. You should tighten them slowly and evenly in half turn increments so the springs all compress evenly. Once hand tight back it off until the friction disk can move around between the midplate and the pressure plate. Otherwise the hub won't be able to move properly to line up everything. The last point which is possibly the most important and is not mentioned in the manual or anywhere at all is that the friction disks are actually not symmetrical. There is a very, very subtle asymmetry to the fingers where they mesh with the hub. These fingers need to be pointing towards the midplate. This helps to make sure the friction disks stay engaged with the hub. Otherwise there is a distinct risk they pop up and out of the hub while you assemble, leading to the warped pressure plate I posted initially.
    • ..m'kay.... I see on my phone you're having difficulties interpreting the artfully hand drawn R31 wiring diagrams... you wouldn't credit it, but they're actually more accurate than those colour diagrams in gregory's and the like... ...for your purposes though, the wiring colour legend is on sheet 1.... ....the fuel pump connector is top right on sheet 2.... ...pin1 (black) goes to chassis ground -- pin5 (light green/red trace)... The best way to navigate those drawings, is to open them up in whatever image manipulation/paint program you like, and use the straight line/ruler  tool (with a highlight colour) to trace along the wire lines...not hard, no rocket science involved... Fun facts: The OEM diagrams are drawn to top trim level spec ~ so for example, you're looking at Silo spec wiring, but the base S3 Executive trim is also covered by the same drawing (base models just don't have all the add-on luxury bits) One of the more sublime bits of errata, is this bit... The wire splice between pins7,14 doesn't exist (red) -- the bridge on the cluster PCB between the same pins (green) does exist...but it's not 'there' physically...it's actually more towards the center of the PCB, exactly at the spot where they tend to crack...and if it does, only half the dash lights work... can drive you nuts chasing it ; don't ; just solder in the missing splice... These are 'intentional' soldered and taped splices inside the loom(s) ~ there's also unintentional splices like this, due to manufacturing process when a spool of one particular coloured wire runs out, and they splice in/on a new spool. Those splices above are in the loom, LHS, underneath the front guard panel (remove to get at loom)... if water's gotten into the looms, you can expect corrosion at these splices ... keep this stuff in mind, if in the future you get any weird electrical faults... 👍
    • that looks identical to the WGNC34 Stagea one I was poking around the other day. Is the other end of that not the ECU plug? If so checking continuity at both ends will tell you which ECU wire it is.  I can start by telling you ECU pin 31 is the top of the large pins on the right in your second pic
