Hiya guys, getting ready to upgrade my fuel pump and injectors for my 33 GTST and got a few questions!
1. What pump should i look @ getting? (how much is it??)
2. How much can my stock injectors flow?
3. Are they side feed or top feed?
4. How much can CA18 and SR20 injectors flow and are these side or top feed?
5. Can i use 13B injectors?(if so how much do they flow?)
6. Any recommendations on what injectors i should get, how much they cost and how much they flow?
Any help on these 6 questions would help me out a whole bunch! thanks in advance!
Cheers
:(:);):cheers::cheers:
https://www.sau.com.au/forums/topic/34081-injector-and-fuel-pump-question/
not enough info, what are you chasing power wise, this will ultimately be the deciding factor on what sort of fuel pump and what size injectors are needed. Also, what sort of management do you have, as some management will run high or low impedance injectors.
RB25DET has side feed high impedance injectors, 370cc.
Thanks Steve, can i use S15 injectors in my car?
Chasing about 270-270kw ( i think thats when the turbo will max out.
Im going to be running a Microtech.
Already have the cooler and 3" from turbo back.
Cheers
should be ok. As a rough rule of thumb, on 6 cyl engines, injector cc approx equals bhp that can be supported.
Microtech should allow you to run either high or low impedance injectors, S15 injectors would be a straight swap though, and will fit into your fuel rail perfectly.
fuel pump, something like a bosch 910 or 040, I think they are available for under $300.
You can use S15 injectors but finding 6 would be difficult cos they are from an SR20. You'd need to buy 2 sets which isnt all that economical, so you might aswell just go buy a new set of 550ccs.
Also a Walbro 255L/ph should be suffice, or the Bosch as previously mentioned!
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
    • @KinkstaahKrinkle paint the "silver" alloy, not the red filter frame Engine bay heat won't be a issue worth worrying about as the silver alloy blocks it off on 3 sides, as for the top, the bonnet seals most of it and the big OEM CAI intake snorkel is still fitted in its original position  I will head into Clark's Rubber when I have some time to grab some pinch weld to tidy up the alloy after I paint it As for performance, I honestly wasn't expecting any, the only reason I got it is because the intake noise sounds cool to my old ears when I'm feeding it the beans Sometimes it's the silly things you do in in life that gives the most fun, and I do love anything that makes cool car noises In other news: I survived 4 nights at sea with Jackie not throwing me over board, holidays are continuing now as we are currently chilling at the Beachcomber in Toukley, after taking the coast roads from Sydney in the MX5, top down all the way, Toukley is where I spent a good deal of my youth holidaying during the summer months, there's lots of reminiscing going on,  and lots of beaches and old houses to visit Next on the list is to head to Batemans Bay for a few days, but we will take the Commodore out to stretch its legs, then Commodore hasn't really moved for months
    • There’s probably people who’d like to do it and then when it comes to putting their hands in their pockets they’ll all disappear into the shadows
