Salling For A friend
Make/Model: TRD Toyota Chaser
Year: 1998
Kilometers: 97,000Kms
Transmission type: Manual
Engine: 1J
Colour: White
Modifications: Trust Cat Back Exhaust, HKS Intercooler, Aftermarker Oil Cooler, Coilovers, Power FC With Hand Controller.
Roadworthy Certificate: NA In SA
Accident History: NA
Asking Price: 22.500 ONO NOT INTERESTED IN SWAPS OR TRADES ONLY GENUINE BUYERS
Contact Details: Contact Sarah Afrer 5PM On Week Days, Anytime Weekends On 0411 518 540.
Other Comments:
* TRD Slotted Brakes With Top Secret Pads
* TRD Full Body Kit
* Rays TRD Sport 18" Wheels (Front 18 x 7.5, Back 18 x 8.5, +45 Offset All Round)
* TRD Steering Wheel
* Sunroof
* Factory Tinted Windows
* Electric Windows and Mirrors
* Climate Control (Air Conditioning)
* Kenwood Double Din CD Player
* Factory Optioned Carbon Fibre Consol Shroud
* HKS Turbo Timer
* Tourer V Floor Mats
* Airbags
* Traction Control
First owner in Australia, Imported 2 yrs ago. Regulary serviced and has been dyno tuned (dyno sheet available). Currently tuned to standard 10psi but can be tuned for over 200KW by adding more boost. All tuning has been done by Steve at (Steve Knight Racetech). Car has done 96,300Kms, very reliable car. Just had 100K service two weeks ago.
https://www.sau.com.au/forums/topic/340813-98-trd-chaser-jzx100/
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
