r33 gtst 97 model manual
new tyres all round
17 inch avs rims
new topsecret bumper
just had timming belt and water pump and that done on 10/10/10
dyno tuned to 10psi 280.4hp capable of lots more''
tein coilovers
m spec front mount
after market alloy radiator
boost control
boost guage
air flow converter computer
boxed in pod filter
110,000kms
12months rego
jensen dvd cd player
i no i have probably forgotten lots but ill fix it later
im in cessnock in the hunter valley askin $13.550
or swaps for vx commodore or newer preferably a vuss ute..
call or text levi on 0417422508
Edited by levi muzz
https://www.sau.com.au/forums/topic/340830-97-r33-110000kms-280hp-12-mths-rego/
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
