Yep, that's pretty much the guts of it. But (at least from my point of view, and not just trying to defend the A1RM here) the A1RM is cheap enough, that even if you went through rotors twice as quick, you're pretty much at the same level as having to buy a $300 race pad from one brand, and a $100 street pad from another, and you haven't had to worry about changing pads between street/track, or their compatibility between compounds...
From peoples comments it seems that the A1RM wears rotors nearly as bad as a dedicated track pad but with lower performance.
I have not personally tried to A1RM but it seems everyone agrees those pads are aggressive on rotors for daily driving. You often compare them to DS2500s which are more expensive. When comparing the two we should note that the DS2500s are very friendly on rotors, by this I mean there is no way you would wear out a set of rotors in 20,000kms from daily driving with a bit of track work.
So fair enough the A1RM is cheaper but if used as a crossover pad as you suggest but will probably end up costing you the same or more as using DS2500s due to rotor replacement costs. On the other hand they sound like a reasonable track only pad for their low price.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
