  • Replies 55
if i get plenty of notice, and i'm not busy then (when you announce date)... then i might just have to put money aside for this one.... :) dunno though... depends on how tight budget is... might have to just come and watch... only time will tell... :spank:
you have lots of notice
look like early april
questions
i use my standard road car s13 silvia
my brother and i used it the last drift day i held the car did over 140 km and we used two sets of tyre
the first set shredded becasue i did 4 full laps in a row
if you let your tyres cool abit they last forever
pete
Yeah Baby lets see if i can destroy this perfectly good HR. This time im disconnecting the HICAS!. I`ll be pickin it up tomoz and hopefully ill have the gearboxes changed on sunday. then we`ll see what the crappy NICS motor can do before i destroy it YEAH BABY. oh yeah back to the thread count me in Fatz just don`t expect me to go fast on the doosie.
depending on date....I'll drop by and teach you a few things :)
:bahaha: Nice one Duncan... I thought that fatz was the only one to have your car intentially slideways! :mad:
IN IN IN :wavey: IN IN IN :wavey: IN IN IN :wavey: IN IN IN :wavey: IN IN IN!!!
2.  How much tyre wear do you usually get on a day like this?
It seemed to depend on the car.
I'm running stock power and wasn't constantly linking corners, so one set lasted the whole day, as they did for lots of other people.
However, guys who had lots of power and smoked it a lot (like the Autostyle Skylines) and those who were linking corners and doing sway drifts down the straight (like fatz) needed more than one set.
I've got a reasonable amount of power (nothing huge, but enough) and I only managed to send my outside tyre bald.  I'm still a newbie though, I'll be giving the next set a MUCH harder time :cheers:
crikey i'll be in my stocker silhouette
shithouse in lowdown power. but i'll be giving it a go.
should be fun boys
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
