I think most games have updates as they are built to be compatible with the older system software (for those that don't go online) and then the update brings them in line with the system version you have..
  • Replies 146
Makes sense if you put it that way.
Anyone else like the emphasis put into the bouncing titties from deadly alliance and after?? I thought it was pretty sweet. Also the way each character would get more bruised up and have blood run down their body. It's these little things that make the games cool.
That's it!
I am plugging the PS2 back in and playing MKV
:no:
  • 2 months later...
For those interested - Gamespot.com interviewed the Lead Designer at Netherealm Studios about the upcoming game based on MK1 - Ultimate MK3.
http://au.gamespot.com/special_feature/most-anticipated-2011/day-2/index.html?page=1&tag=topslot;thumb;1
Liu Kang Story Trailer
Game seems quite awesome. Although I think the motion doesn't seem fluid enough (unless it's just how the guy plays)
Kollector's Edition looks cool - not sure about pricing yet.
WTFFFFFFFFFFFFFFFFFFFFFFFFFFF!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
This is FKNG stupid!!!
But, fair enough... I'll just buy it from overseas. Not my problem if the classification board like to deny aussie retailers a fair trade.
lol.... but the Saw movies? No problem.
Useless f**ktards.
Not that I'd be buying MK9 anyway, but it is the principle.
I am sure that there are a number of Hong Kong based eBayers that will be selling it.
Probably quite cheaply too.
Is there anything on the PS3 side that would stop us importing it and playing it? Region issues? System Updates blocking it?
No.
No games are region locked on PS3 and there is no way Sony would release a System Update to stop a game from being played.
The only region issues that the PS3 has is DLC. If you purchase and download an add-on through the Aus store, you can only use it in an Aus user profile (same goes for US, JP, Eu user profiles). Downloaded games aren't even region locked.
    • How to wreak havoc at a bogans party... Swap out the goon bag hanging from the clothes line with oil bag... Watch chaos ensue during Goon of Fortune....
    • Hey everyone,   I’m looking for some advice on replacing the timing belt on my RB25DET Neo-powered 1998 Skyline. The engine was fully built about five years ago, including a fresh timing belt, water pump, and other essentials. However, since then, the car has only covered around 2,000–3,000 miles. It’s currently making around 650hp.   Even though the mileage is low, I know timing belts have a time-based lifespan too, and most recommendations suggest changing them every five to six years or 50,000 miles. Since I’m at that time mark, I’d rather not take any risks and plan to swap it out soon.   A few things I’d like to hear opinions on: 1. What’s the best belt for this setup? Should I go with an OEM Nissan belt, or is the HKS fine-tune a better choice given the power level? 2. Would you bother replacing the idler pulley and tensioner at the same time, or only if they show wear? 3. When swapping the belt, is it necessary to lock the cam and crank gears in place, or is lining up the timing marks enough? I’ve seen different approaches, and I want to make sure I do it right.   The water pump was changed with the rebuild and isn’t run off the timing belt, so I don’t see a need to replace it again. I just want to make sure I approach this the right way.   Any insight would be much appreciated. Thanks!
    • How does this compare to the internally gated g25-550 in terms of power production at same psi and spool
    • Did you find that your voltage of the battery wasn't where it's normally supposed to be? for example on my r34, it's at 14.5v when running after a few seconds, but I noticed when I had a rough start and it initially wasn't idling correctly, the voltage on my triple gauge cluster was showing lower than usual. Seems like the alternator is starting to crap itself
