i have a used h 300mm x L (outlet to outlet)780mm thickness 80mm with 3inch inlet/ outlets.
And heps of pipes and joiners and clamps! the cooler has a few bent fins nothen major, clean inside $100 pick up in Whittlesea
https://www.sau.com.au/forums/topic/340913-intercooler/
Hi, What make is the cooler? tube and fin or bar and plate.pic would be appreciated
Alex 0433 878905 Campbellfield
https://www.sau.com.au/forums/topic/340913-intercooler/#findComment-5503869
hey. can i see the pipes.. any return flow pipes.. thanx
sorry its not a return flow cooler, and the pipes i have are just bits n pieces that i have lying around as spares
i will post a pic after work tonite
https://www.sau.com.au/forums/topic/340913-intercooler/#findComment-5503909
hay mate im sure its tube and fine, can see any brand on it! i will post pics tonite after work
https://www.sau.com.au/forums/topic/340913-intercooler/#findComment-5503913
  • 3 weeks later...
    • This was a huge help.  We followed the steps,  although shifting into 2nd was actually into 3rd for us,  and 1st was into 2nd ( steps 9 and 11) .  The long flash was the 4th flash.  So shift solenoid A is possibly the culprit.  Is this inside the transmission itself? Or is it accessible by just front the pan? Or is it bolted to the outside of the transmission?  Thanos for your help everyone
    • Can you enlighten me on your best practice regarding these hoses? I don't wanna make the same mistake if you already got a better solution.
    • I have some silicon hoses already, for example engine to watercooler. But yeah, I get the sentiment. The lower intercooler silicon hose is drippy too, despite not being very old. Does anyone except Nismo make these same lines out of rubber? Long term I think they'd be the better replacement, especially since the car won't live as hard a life anymore as in the past nor be driven as often.
    • I know most issues are just age related. But for example the turbo oil drains, there is dash adapters for these and you can just make a braided teflon line for them and (probably) never have them leak again. Also not terribly expensive. Can you even get the factory hardlines from new? Or are they repairable if they break?
    • I know it'd be much much easier with the tool. I hope I can find one that won't take 3 weeks to get to me an isn't a "Asian models kit" that has tons of (to me) useless adapters for a load of cash.   It's a summer project/fun car. I do wanna enjoy it, without endless downtime over and over. So yeah I would even go and buy an engine crane + stand to save myself the trouble of hard to reach or unreachable places going bad later on. Would also be a good opportunity to put on a Fluidamper, renew the mains seals and stuff like that. I have some money on the side that I can use for that, what I wouldn't want to or be able to do is let everything be done by a shop or have my engine completely rebuild right now. I intend to do most of the "doable" jobs myself. Pulling an engine can't be that hard, can it?
