Ok what we have here is a R32 GTR rolling shell with full interior all panels and glass complied registered.
Originally I planed on removing the ABS, air con and manual gearbox, stripping the engine bay and re spraying and putting my complete set up in with all wiring hidden and full auto but have since lost interest. All I got up to was stripping the bay, welding majority of holes and high fill. The ECU runs a Map sensor so the original air flow meter plugs have been cut off the loom :P, but the rest of the full loom is there, boot cable is broken so will not release form in car but fuel release works fine, also rust under paint on driver door bout the size of 20 cent piece
So heres what you do and don’t get,
DOES NOT INCLUDE
Engine
Gearbox (can supply R33 GTR box with blown 3rd gear)
Intercooler
COMES WITH THE FOLLOWING BUT NOT FITTED
ABS unit or front brake lines
All A/C components (may be hard to fit as lines to heater box have been cut with hacksaw)
Brake booster and master
Clutch booster and master
Rear Diff fully reconditioned new bearings seals
Blitz blow off valves X2
HKS super dragger exhaust cat back
All front guards lights, front bar everything missing from pics 3 & 4
Paint (for engine bay)
COMES WITH THE FOLLOWING FITTED
R32 GTR wheels with Re55 semi slicks
All Brakes
RDA slotted discs
QFM K750 pads
HKS hypermax II coil overs
Autronic SM4
CDI 500R
Advan surge tank
Bosch 040 in tank pump
Bosch 044 ex pump X2
Supporting Fuel lines
Hi cas lock bar
Battery in the boot
All interior in pretty good condition apart from usual bubble in dash.
Feel free to PM me anytime with any question or queries, any photos just send email address and I will forward them.
also note im possibly willing to separate some parts if the person buying does not require them, BUT the interior and body panels will NOT be pulled apart.
Cheers
located north/west suburbs Victoria
$12000ono
Please do not tell me you can get a complete running GTR for 15,000 im not interested.
https://www.sau.com.au/forums/topic/340951-r32-gtr-rolling-shell/
Someone could buy this, buy my engine and box and vola gtr for the win!!
good luck with the sale mate, if i had the money i'd be doing exactly what i said above!
sounds like a plan although i will have a complete engine for sale later next month as well that was built for this car.
if u split im interested in the wheels with the re55s....how much tread on those??
cheers.
will keep posted about the wheels although i would prefer to sell them with the car as then it wouldn't be a rolling shell.
and to all the people asking bout the fuel set up if i do end up separating it i will post it on another page separately so we can go from there.
but at present i am not separating anything just yet.
cheers
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
