I just ordered three new panels from these clowns and they arrived damaged, and even tho I paid insurance, they wont take them back and give me my money back! They want to get a "quote" and have them repaired! what a joke!
be carefull who you use gentlemen! there are alot of hopeless bad businesses out there who dont really want to stand by you!!
i got a mate who is a panel beater. when they get panels delivered he opens them before the delivery driver leaves and any that are damaged he refuses to sign for for pretty much this exact reason. i think you'll find a lot of companies are like this. they are probably forced into being like that a little bit by some dodgy customers. there would be people out there who would damage the panels themselves out of their own clumsiness who then try and get the panels replaced for free.
