i have for sale a used apexi power fc with hand commander for a s1 r33.....
i bought this item second hand about a year ago and never managed to get around to putting it in. now that i have found out that my series 1 is actually a series 1.5, i definately won't be putting it in lol
i am asking $1200 ono pm or email me at [email protected]
will try post some pics soon or email them to you
wuts the difference between using it in a series 1 or 2 engine anyway? i thought it was the same pfc for both?
i know the ignition system is different from series 1 to 2.... not sure what else really.... but when you c the apexi's for sale they normally list whether there for a series one or two....
other then that i don't really know.... if anyone could shed some light it would be appreciated.
yeah im pretty sure there only one power fc for both series of rb25det. as far as i know the coilpacks and AFM are diff mayb something else, but the power fc can be tuned with both versions of those things. so u will be able to use it still if u dont wanna sell it.
was just lookin on one of the apexi sites.... they sell a power fc for a series one and another for a series two, so im a bit confused. can't find an email address or a link to email them and ask..... will try and find out. might sell it anyway
1200 delivered to3189 n I'll take it 0433663833 thanks
    • If doing that ^, I'd take the idle up valve out and plug the hole in the pump.
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
