hey all, just trying to wonder what the awd system of the stage is based on? (s2) so r33 setup
is it a mechanical diff or electrical diff?
torsen, viscose etc setup???
from what i know and have been told, it stays in rwd until it feels that the rear is exceeding its torque output and to stop it from slipping it will engage the front.
or is it just clutch driven??? clutch is disengaged until it feels slippage etc and then presses clutch together to connect the front wheels??
Jean
https://www.sau.com.au/forums/topic/340964-c34-stagea-awd-system/
  • Replies 49
at the rear of the gearbox is a 4 or 5 row chain that wraps around the exit shaft
the chain runs into the transfer box where it meets the front drive shaft
between the shaft and the chain is a series of clutch packs which are designed to slip al little (a bit like an auto box) when some power is needed up front, the pump adds pressure to the clutch packs and some of the torque/power is transfered to the front wheels
the max power to the rear is 100% and when the clutch packs are fully engaged the torque split is 50:50
Thanks for posting this info up. I was also wondering how the drive system works.
Dunno what you'd have to be doing to get 100% driveto the front wheels or 50:50 as you also called it. Even "popping" the clutch at 4000rpm while rolling in 1st gear with my brass button exeedy clutch makes the gauge for the front drive move a lil bit.
aaaah, this is pretty cool. sounds interesting, may google more
I ran it through Google as well (on between load 200ton trucks at work) and found some great info on it on Wikipedia. There was even a video on it! I will be having an indepth look as soon as I get home.
Its a bloody awesome drivetrain. The Japanese are bloody Clever!
Max power while the system is operating normally is 95% to the rear. This is why you can't just pull the fuse to go in to 2WD mode, there is a procedure and it works, 100% RWD.
The system is pretty much based on the R33 GTS4 system, runs 5% preload to the front and splits more torque as it feels it's needed.
Another truck driver or a loader driver at a mine? I drive container trucks - mere 45 tonne max!
Yup. I work in a coal mine. I operate the smallest Digger there which weighs 300ton. Most of the others are 600tonners and the largest 2 are 1200tonners... Those babys can dump 100tons of dirt on a truck in one scoop! :D
anyone got the link to that rwd procedure (the one that you can leave the front driveshaft in)
I have posted it up a number of times...
But here goes again..
Locate the "air bleed" wire behind the drivers kick panel, it's a plug with a single wire either side (usually green socket, white plug).
Disconnect it.
Start car. As key comes back to the ON position, within 10 seconds, depress brake pedal 5 times, 4WD light will start flashing to indicate you are in 2WD mode.
To go back to 4WD mode, turn car off, reconnect plug and off you go.
I have hooked mine to a switch in the centre console.
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
    • From there, it was just a quick electrical check, prime the oil and start her up Which, is not what happened. 1. Bloody seppo Aeropro battery holder. Not only was it too tall for the battery (which I'll forgive them for, I have another battery the same nominal size that is taller than Neil's one, but the bracket is a fixed height so the battery was spaced up) But the thing that really shits me is the hardware to hold it on requires a 7/32 Hex key. WTF. No-one will ever be able to remove or install the damn thing without a hex key they don't own 2. Kill switch no longer worked once the console was installed. Neil mentioned above he had to adjust the length but it no longer cleared the console once installed. Sorted. 3. Suspiciously, the brake light holders were hanging in the boot with no globes. Sure enough the stopper on the brake pedal was missing so they are always on unless the kill switch is activated. Will pick one up tomorrow (turns out 32 and 33 don't use the same stopper) 4. All that sorted, I turned on the kill switch, turned the key to ACC. Nothing. Turned it to IGN. Nothing. Checked some fuses and found the main IGN in the boot was missing which improved things once it was replaced. Now ECU and dash lights turn on with IGN but still no fuel pump. 5. Turned it to Start....ECU on, no fuel pump, no starter. Plus the voltage dropped straight to 9v.  I suspect the starter is f**ked but am going to have to work through it all and see what is happening, really looks like more than one issue. Does anyone have the R33 fuse box key with the circuit it sources from (eg BAT, ACC, IGN, SRT etc) and supplies? I can find a translated list showing Amps and circuit without supply circuit, and I can find supply circuit without Amps and target circuit.
    • 3rd time lucky, the AAC is now all plumbed up after getting some final fittings All set up under the plenum of maximum access
    • OK, so the weight has been bugging because it was really low. I did it again today and got a more believable answer at 1246 without driver And with a 93kg driver I'm pretty sure the car was still slightly on the quickjack last time meaning the full weight was not on the scales
