"dimple" Neodymium Magnetic Sump Plug Group Buy!
  • Replies 200
I'm just making payment to them now so at a rough guess maybe 2 weeks time give or take. Since this is the first time dealing with this supplier I don't know how long their processing/shipping takes. Could be a lot quicker though :)
Hahahaha yeah my damn group buys seem to fill very quickly :P
Just to confirm, payment for the first batch of 35 plugs was made yesterday and they are getting the order ready to ship once payment has cleared.
Every one will end up getting one in the next batch, don't worry :D
how much did you sell them for??? also can you do another group buy????
and how does it take to recieve them???
thanks heaps
  PM-R33 said:
Hahahaha yeah my damn group buys seem to fill very quickly :)
Every one will end up getting one in the next batch, don't worry :)
Hey buddy, have a quick read through the entire thread and you will understand everything that is going on.
To sum it up I didn't think they would be as popular and obviously the numbers involved is very high so we will do batch orders.
The first batch of 35 has just been paid for and once it has arrived and every one is happy we will do the next batch.
You can find most of the details on the first page.
Cheers
Phil
Edited by PM-R33
Good to hear Phil!
Yes, if the GB and diff turn out to be the same size, I'll be in for another 2 myself come next batch :)
These things went like fking hot cakes.
  samuri said:
Or just buy a Neodymium Magnet locally and whack it on your oil filter.
They are so damn strong and could then be transferred to any car
They make them aswell :D
http://www.drainplugmagnets.com/blackhole6packfilter.php
  PM-R33 said:
UPDATE
Tracking number has been receieved. It is coming by USPS First Class so might be here pretty quick!
First Class eh.. *pulls out Monocle*
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
