http://www.trademe.co.nz/Trade-Me-Motors/C...n-328966931.htm
Im pretty sure they have sold the cvt boxes a long time ago but you might get lucky and they may have a cvt ecu...dunno.
Possibly contact an ecu specialist.. i think plms developments over there may be able to help but not sure if they do anything other than engine ecu's.
What a champion you are mate! Thanks a million! :)
I'll get in touch with them to see if they can sort me out.
Thanks again!
What a champion you are mate! Thanks a million! :P
Thanks again!
You should let them know if they can fix it then they may have some more customers if it ends up being a common fault on the cvt cars awell.
Maybe some of the autos might fail from this issue aswell who knows....
Strange though that the cvt ecu (that you would think would be different) possibly has the same issue as the autos....
****************************MAJOR UPDATE & CONCLUSION************************************************
YES! Finally fixed! After a month of horror and a long list of possible culprit, I finally figured out what was causing the problem.
The problem was...(drum roll) :FAULTY SPEED SENSOR
After spending a week at Tech Transmission with no end result and spent close to $500, I went and took the car to Jamie at Autoworkshop at welshpool cause i couldn't get an appointment soon enough with Fabcar. He hooked up a scan tool, recorded the datalog and told me to go for a drive. As soon as the car was jerky i took a look at the scan tool and the vehicle speed sensor was going haywire. Jumped from 50 to 75 dropped to 4 then finally made the transmission go on limp mode. Sure enough after that he retrieved a P0720 (Vehicle Speed Sensor) Error from the TCM. He had a wicked scan tool.
Got a replacement from Nissan ($300) and fitted it in today. Problem = Gone :blink: I'm so happy i can eat a horse.
Here's the part no for the speed sensor: 31935 - 5P002
I hope this info would be useful to anyone who's experiencing the same problem.
Thanks to Jamie & Brett at Autoworkshop who diagnosed and tested everything on the car. Thanks to everyone here who’s helped.
Sorry for the long post, i'm just too excited right now, My baby lives again! :(
Edited by dodes47
Got a replacement from Nissan ($300) and fitted it in today. Problem = Gone :ermm: I'm so happy i can eat a horse.
Sorry for the long post, i'm just too excited right now, My baby lives again! :D
Thats great you got it sorted and gave the details on the problem and solution it just shows how important a good scan tool is with these modern ecu's.
I want to get myself a consult3 or equivalent at some stage.
  • 1 month later...
Doddy
I think I have a similar problem to what you had. Mine starts to jerk a bit then the tacho goes to 4000+ and stays there. No matter what gear i put it in, the tacho does not change. It's as though I'm driving in 2nd gear. Only way to get back to normal is to stop the car and restart.
Did you change the speed sensor yourself. If so was it much hassle and where is it located?
Bob
Bob
It sounds similar. But my tacho will go up as high as I want to rev it. My gear will get stuck in 2 or 3. While u may have a speed sensor problem, it could be something else as well.
My suggestion is take it to a good mechanic with a good scantool that's able to talk to the ecu/tcm. It should pull up a code You need that code to go on. Don't make the same mistake I did and try to guess the problem.
Btw the speed sensor is located on the gearbox itself. There's two of em. Input and output.
Goodluck let us know how u go
hey wheres the speed sensor located
my cousins car is going through the problem in the limp mode and hes been to so many work shops and when they scan the car it comes up all dese codes which cant be erased and it has nothing to do with the solenoids ay but the codes said it does
P0720 VEH SPD SEN/CIR
P1762 D/C SOLENOID/CIRC
P1752 I/C SOLENOID/CIRC
P1757 FR/B SOLENOID/CIRC
P1772 LC/B SOLENOID/CIRC
P0745 L/Press SOLENOID/CIRC
Ok. Is the car a GT8 or 5sp Auto? Mine is a GT8. So while i'm sure it's exactly the same electrical wise,i can only give you advice based on my transmission.
I'd say that because the Speed Sensor code is at the top of the list might as well give that a fix first.
I recommend taking it for a test drive with the scan tool hooked up and logging the input from the speed sensors and the solenoids. When the problem occurs and the car goes to limp mode you'll definitely see what's causing it in the scan tool.
In my case the speed sensor started going haywire and giving erratic data to the ecu. That's why my car went to limp mode.
The speed sensor is located outside of the transmission housing itself. You need to have good access to the bottom of your car. The input is at the front and output (most likely the culprit) is at the back. You can't miss it.
If you wanna take a shot at fixing this your self firstly check the harness and continuity for the speed sensor (a multimeter would help) if you can rule this out then call any nissan dealer in your area and get a hold of this part : 31935 - 5P002 (Vehicle Speed Sensor) Picture attached.
The input and output uses the same part. So you can swap the input and output if one doesn't fix the problem. This should set you back at least $300.
Goodluck, post back when you have problems/result :thumbsup:
fanx for the the info , its a 5speed auto box
scanned many times and try deleting it & within 5 secs after deleting it , it pops straight back up
will take a look at the sensor first ay, deyv took the whole sum down and check everything and every code and box seems fine so duno wats nxt man
will keep u updated ay
cheers
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Gotta admit, I love the 20b Cosmo.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
