This GTR was built specifically as a timeattack car.
Due to other commitments, the potential of this car has never realised as it's never gets driven enough!
Below is the modification list.
MY1999 model, bayside blue. R34 GTR Vspec
1st owner in Australia from 2006. Total travelled 48,xxxkm
(34500km+12000km on new nismo 300km instrument)
Engine:
Brand new N1 engine was fitted @ 7780km R34 N1 engine ex Omori factory (engine has done less than 5000km since)
Engine was fitted with Nismo oil pump, Nismo plenum
Tomei Metal gasket 1.2mm kit.
ARC 100mm twin entry intercooler, aluminium piping kit
ARC radiator
ARC oil catch tank
HKS 680cc injectors, HKS twin entry fuel rail, HKS fuel regulator
HKS oil cooler kit
Ross balancer
Twin fuel pumps, Bosch 044 fuel pump /surge tank setup, walboro intank
GTauto intake
Autronic SM4 ecu
Drivetrain
Exedy Twin plate clutch
Carbon driveshaft
Turbos & Exhaust
Nismo R1 turbo kit ( similar to N1 turbos but better flow)
Tomei down pipes
Fujitsubo equal length front pipe
Metal cat
Trust 90mm titanium cat back exhaust
Suspension & Brakes
Endless Super Function adjustable coilovers
Endless 6pot 355mm front racing caliper kit with Bathurst spec enduro race rotor & pads
Endless 4pot 330mm rear racing caliper kit
VOLK TE37 18X9.5 / RE55s tyres
Cusco front camber arms
Exterior & Interior
MOMO Race steering wheel/quick release
HKS EVC4
Nismo white 300km instrument
Nismo MFD II
HKS Kansai half cage
Nismo GT LED lights
Nismo B pillar garnish
Night Rider rear wing extension 50mm
Dyno’d 340kw atw @1.5bar Tuned on BP98
Normally runs at @1.2bar
Asking price is $67,500 ono
currently rego'd till Jan 11, will supply RWC to qld buyers.
Please contact Steve on 0412308533 or [email protected]
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
