I reluctantly have for sale my cherished and much loved 1990 Nissan Skyline GT-R.
This car is in immaculate condition and very well looked after, it is a great example of a clean well modified GTR.
Company car on its way so this one must go. My loss is your gain.
ENGINE:
-Apexi Power FC + Boost Cont Kit
-Apexi Power FC Hand Controller
-HKS Twin Pods
-Splitfire Coil Packs
-Bosch Fuel Pump
-Greedy Adjustable Cam Gears
-Gates Racing Timing Belt (New)
-Greddy RB26 Clear Timing Case
-HKS Super Dragger Exhaust - Turbo Back - Split Dumps - High Flow Cats
-NGK Platnium Plugs (New)
-158,000 KMS
HANDLING + SUSPENSION:
-Nismo Shocks + Coilovers
-Nismo Control Arms
-Exeedy Heavy Duty Cushion Button Clutch
-17" Advan AVS Model 5's (New Rubber)
-Front & Rear Adjustable Strut Braces
-Bendix Ultimates Pads all round (New)
INTERIOR:
-Pivot Speed Meter / Speed Cut
-Apexi Boost Gauge - PSI -30 to +30
-2" Digital Tacho with Shift Light
-Blitz Turbo Timer
AUDIO + SECURITY:
-Alpine MP3/WMA Head Unit with iPod Cable
-Focal Fronts + Clarion Rear Speakers
-Sub/Amp Cables already wired
-Viper Alarm - Turbo Timer + Automatic Windows
SPARES:
-Original Air box + air guide
-Original R32 GTR Computer
This car has made 245awkw 0.9 bar boost on a safe tune.
Top quality oils used including Motul 300v Chrono and Redline.
New Battery, Alternator and Auxiliary belts installed on 16/08/10 (With Receipts)
Asking: $18,900 Negotiable
Feel free to contact me on 0432 326 666 or [email protected] if you have any questions.
Cheers,
Aniket
Note: The interior pictures have been taken without the genuine Nissan floor mats to show the condition of the original carpet.
Edited by anik3t
https://www.sau.com.au/forums/topic/340991-fs-immactulate-r32-gtr-melbourne/
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
