for sale is my '98 model R34 Nissan Skyline GTT.
5 speed manual
2.5 turbo Neo
This car is in absolutely awesome condition, it was imported in '05 and i am only the second owner, i would love to keep it but i am building a house and need the money tied into this in order to finish, so it has to go. below is a quick description, im sure there is more i will forget to include.
registered until 5/11.
looking for $19900 negotiable
it has:
- hks hipermax adjustable coilovers
- upgraded sway bars
- front strut brace
- factory xenon lights
- nismo clear side indicators
- boost switch 7 / 10 psi
- boost gauge
- hi flow panel
- superspark coilpacks
- pioneer double din dvd/ipod/bluetooth head unit
- 5 channel kenwood v12 amp
- 8'' sub, quad tweeters/speakers
- 55000 km
- turbo back kakimoto regu exhaust (the nicest rb rumble ive ever heard)
apart from the above listed items, the car is stock and is in excellent condition and super reliable i have not had any issues what so ever in the 1 year ive owned it.
i have carried out the servicing myself at 6000k intervals.
the previous owner told me the 100'000 km service has already been carried out due to the age of the car.
spares i also have for the car, which where taken off when going for the tasmanian roadworthy include:
- front mount i/c
- apexi air intake and pod
- blitz bov
- momo quick release steering boss kit and wheel
- 19 inch starcorp racing rims, and near new hankook tyres
all these spares will be included in the sale price upon negotiation.
feel free to contact me via email or mobile if you want to ask any more questions or want more photos, i have around 60 photos i can email.
the car really has to be seen to be fully appreciated, so do contact me if your interested.
please NO SWAPS at all, i am only getting rid of this car to free up some money, so unless you want to swap your car plus 19K then i will not reply to swap offers.
car is located in devonport tasmania.
email anti.mediocraty@gmail.com
mobile 0437 580 559
cheers daniel
img-resized.png Reduced: 93% of original size [ 1024 x 768 ] - Click to view full image100_1576.jpg
img-resized.png Reduced: 93% of original size [ 1024 x 768 ] - Click to view full image100_1574.jpg
img-resized.png Reduced: 93% of original size [ 1024 x 768 ] - Click to view full image100_1581.jpg
https://www.sau.com.au/forums/topic/341020-fs-98-r34-skyline-gtt/
  • 3 weeks later...
  • 4 weeks later...
    • Hi Yes we're a bit optimistic we might get something out of sealing up the two pipes of the external wastegate and reactivating the stock one. I believe the orginal stock wastegate was tack welded shut. It doesn't budge and visually looks closed and sealed. The car has noticeably more lag so it could be at least part of the problem, maybe all. It's definately one of the key changes made since last tune. And it's one that's more difficult to fully understand and measure, not like for instance timing or cylinder compression.  Thanks for that feedback, we'll let you know how this progresses. Fingers crossed.   Regards Rob
    • Transplanting the vvt from a 25neo into an rb26?
    • Well, I was going to say, "Is the wastegate set up so that it is not leaking?" That's actually a different thing to what you're asking about. In theory, if you have allowed the two halves of the manifold to commmunicate (more than the stock manifold does - which is at least a little bit) then the negative effect should be apparent in delayed spool, not in outrigth power. OK, maybe just maybe, a badly set up twin scroll wastegate "crosstalk" might kill the top end, although it's hard to see how. What is happening with the original wastegate in the turbo? is it sealed off properly. If it's left flapping in the breeze, it will f**k everything up. If it is still there, and can be returned to service, I'd be capping off the external (presuming the two halves can and will be isolated from each other after doing so) and have a go with just the stock wastegate. I have an internal wastegate in my highflowed rear housing. The bigger opening and flapper should be fine to >250 rwkW. So there's not exactly a pressing reason to have the external. Done right, an external will give better results. Done wrong, it might just be possible to have worse results. Report back!
    • Hi Rob It's a nistune ecu. Yes same shop, good reputation. Apparently the computer on the dyno is compensated for temperature.    Chris was saying that the lean or richness of the mixture would be covered in the actual tune, but he's already picking up in advance that it's under what it should be. Regards the dyno, it's also noticeable on the road. But I just want to add something that has just come in, it appears there might be something in the setup of the external wastegate. In the exhaust manifold there is a centre divider between the front three and rear three cylinders. The external wastegate has a pipe from each side that join at the wastegate. Theory is those two pipes just might be pypassing that divider and introducing a problem somehow. Is anyone familiar with the divider in the exhaust manifold and the effects if the two wastegate pipes were to create a bypass path? Thanks for your questions Rob, interested in your thoughts on this external wastegate bypass theory. Regards Rob
