All fuels have a rich max and a lean max figure to which they work best at, generally anything between the two will be OK. Anything above or below will result in potential detonation or poor combustion conditions.
Richer does not mean safer in all respects, it is generally accepted that richer is safer due to regular 98 properties. We are talking about lamens terms now and this should not be acceptable in something we put this level of money and developement into.
Fuel blends have always been seasonable with many companies, yet actual mixture percentages advertised at 15% variance is shocking.
Hope I didnt break your heart mate.
I'm running a RB20 with 22psi and we can not get it to ping with any amount of timing and it's only running E42.5
Good luck trying to get a car to ping on E70 :D
i have it on good authority that caltex plan to roll it out to more servos around the gold coast in the future. Not sure on the exact timeframe though but it is in the works.
  • 3 months later...
I rang up caltex on smith street a few weeks ago to see if they had E85. They said that currently only Worrongory has it. I asked if he knew if any others were getting it but he didn't have a clue.
Went there a week or so ago, pump was out of action and they had no idea when they were getting another shipment.
  • 5 months later...
  • 3 months later...
    • Surely the merged entity will be called "Honda" given the relative company values. I've got to be honest, I don't understand how merging 2 companies that missed EVs (despite Nissan making the first mass produced one) will solve their problems
    • If you haven't bought the ECU yet, I would strongly consider buying a modern ECU. Yes it is very easy to setup and tune, however it is lacking many of the features of a modern ECU. The pro plug in is something like 10 or 12 years old now? Can't remember exactly but it is very dated now. In that time the Elite was released and now we have the Nexus platform.  I would strongly consider not buying the ECU that is 3 generations old now (especially as it isn't a cheap ECU!).
    • Im happy for it as long as it means reanult gets the boot
    • Sorry I should have been more clear with the previous post.  The block is a sanding block - picture something like this https://motorguard.com/product/motor-guard-bgr161-bgr16-1-rigid-psa-sanding-block-2-5-8-x-16/ The guide coat is the paint It's two separate things I was talking about, there is no "block guide coat".
    • Maybe more accurately, you aren't just dulling the existing paint, you are giving the new paint something to 'grab on to'. By sanding the existing paint, you're creating a bunch of pores for the new paint to hook on to.  You can lay new paint over existing paint without sanding it, might last a year or two then sad times. The paint will peal/flake off in huge chunks. By sanding it, the new paint is able to hang onto it and won't flake off.  Depends on the primer you are using. When you buy your paint, as the paint supplier what grit of sand paper to use before you lay down the primer.  Use whatever you like as a guide coat. Pick a colour that really stands out in contrast to the paint. So say your sanding/painting a currently white car, using a black guide coat would work well. You very lightly lay the black guide coat down, then as you sand the car with the large block, all the high spots and low spots will stand out as the black paint is sanded off (or isn't sanded off).  When you buy your paint, hit up your supplier for recommendations for what paint to use for a guide coat if you're unsure what would work well with your setup.
