Hi guys,
looked under the car with my mech yesterday and found that the bushes on both side of the car has cracked.
Sorry i don't have a photo but the on the front lower arm of the car, the bushing that is towards the back of the car is the one i'm referring to.
It would cause the wearing out the front tyres quick.
Nissan would only sell them bushes WITH the arm, like $200+ each side
Anybody used these replacement bushes before? R these the correct ones?
http://cgi.ebay.com/ebaymotors/G35-350Z-Fr...sQ5fAccessories
Anybody with experience with the bushes pls share :D
Cheers!
https://www.sau.com.au/forums/topic/341075-cracked-bushes-front/
Same thing happened to mine, I went through nissan and had both sides done inc. labour for $180 a side.
It wasn't long after that that I saw that you were able to just replace the bushes, and yes they will be the bushes that you are after.
Been there, done that. Nissan NZ quoted me NZD$400+ (might have been closer to $500 - can't remember exactly) per side for the whole arm so you got off lightly with that quote!
As per the last post you definitely can replace just the bushes. Mine were done under a mechanical warranty, and the warranty co told Nissan to get stuffed with the quote for the arms and instead sourced just the bushes themselves and supplied those to the dealer. Got fitted with no dramas - now no more nasty squeaks from the front of the car.
This is a quote i got a few months back on the parts
Whiteline: www.wholesalesuspension.com.au P: (02) 4721 2112
F Control arm - lower inner W52991 1 $50Available
F Control arm - upper inner W52988 1 $65Available
F Shock absorber - control arm W52992 1 Lower shock bush $50
R Control arm - lower inner W62996 1 $65 Available
R Control arm - lower outer W62535 1 Locates in hub $55
R Control arm - upper inner W62989 1 $165 Available
R Shock absorber - hub W62535 1 Lower shock bush $55
R Subframe - mount W92994 1 Traction control $175 Available
R Trailing arm - lower front W62997 1 Lateral arm $80 Available
R Trailing arm - lower rear W62999 1 Lateral arm - locates in hub $25 Available
R Trailing arm - upper front W62985 1 $55 Available
R Trailing arm - upper rear W62998 1 Locates in hub. $50 Available
R Diff mount insert W93189 1 Traction control $55 Available
Hey there I just got a quote to replace the F Control arm - Lower inner and F Control arm - upper inner from www.wholesalesuspension.com.au for:
Parts was $65 and $85
Labour $600
Is this a good price?
