Having troubles with my gtr, here are the symptoms:
Power: 320awkw
-When under load in 1st and 2nd gear it feels normal (fast) but i put it into 3rd it feels "slow"
-Then it decides to be slow in 1st and 2nd then fast in 3rd
-Literally 5 seconds later i boot it again to see any difference, it decides to be fast or slow in random gears
-The car has a f**ked clutch booster, its making the squeeky sound and is leaking air, could this contribute to the problem?
-I have checked my hand controller, at idle afm 1 is sitting at 0.1 and afm 2 is on 0.15 volts (actual numbers are afm1 89-94 afm2 1.06-8
-Under light load in neutral it gets closer to 0.2 difference and when i back off it goes to 0.27 difference
-Abd drops alot faster than afm 2, is that too much of an variable for those afms?
-The afm's are Z32
It sounds like a afm problem but i could be wrong.
Edited by Sedat
https://www.sau.com.au/forums/topic/341089-having-problems-with-my-r32-gtr/
Just tested the car underload and the results were
AFM 1: 4.19 volts
AFM 2: 3.88 - 3.98 volts
at idle
AFM 1: 0.91
AFM 2: 1.08
Is it normal for AFM 1 to be lower at idle and higher under load? And is that an acceptable variance?
The car has been running perfect today, no loss of power at all so i am stumped as to what the problem is. Any help would be appreciated and if this is in the wrong section can it be moved please
silly question, but have you earthed the fuel pump? takes 5 mins to do and eliminates so anoying and potentialy destructive problems
Not sure, car was bought as is besides the tune i had done to it a month or so ago. Have had the car for a year and a half and this is the first time it has done something like this :D
    • Well some mostly good news and some slight bad news.  Good news is cylinder 6 did in fact only require a honing and I'm good to run my 86.5mm pistons again. I should also get the block back by end of week. Bad news, had a few surprises pop up. First, main and rod bearings were trashed. No sign of any heat damage. I knew right away what caused this... I had not packed my oil pump originally and spent a lot more time than I would have liked cranking the motor to get oil pressure. It sounded fine once started so I chucked it up to luck and forgot about it. Luckily rod and crank are fine and just need new bearings. Engine builder agreed that this was the cause.    Another surprise that carbon covered up very well that I didn't catch, something got sucked up and went through cylinder 1, 2 and 3. Luckily this was no cause for concern, just needed a bit of cleaning up. Valves look fine but he will vacuum test the head this week to confirm. I'm presuming this was something left over from welding my intercooler piping, but we'll never know. I'm going to thoroughly reclean everything.    So all in all, happy the motor is fine, and I'll get it back much sooner than expected. I'll also be taking the time to convert my WMI system over to direct port. I'll snap some pictures of that when the parts come in.
    • I understand, thanks. Yeah I wouldn't want the car to tip over, I'll try and use the sills, I don't want to risk smashing the chassis rails. I ordered some rubber pucks that have a hopefully big enough slotting. If the front right gives me trouble I can always just make a wood block. I'll measure and inspect the sills closer once I actually take the car up. I hope so, but the rubber blocks I had in hand so far were pretty damn firm, if they are that hard they won't give much way. I'll let you know what happens. Angle grinding rubber isn't one of my favorite tasks. I'll probably start a build thread soon, for my own documentation and "log" as well as sharing what's going on with the car.
    • Kinda something I have been thinking about.  To be honest, we bought it already driving like that.  So there's no telling how long it actually has been driving like this.  Hopefully damage is too bad when we drop the pan.   I am having a hard time finding a site that sells the solenoid for the 5 speed auto, do you have any suggestions?
    • That'll be most likely down the road...  LOL
    • a stock / option or aftermarket?
