Having troubles with my gtr, here are the symptoms:
Power: 320awkw
-When under load in 1st and 2nd gear it feels normal (fast) but i put it into 3rd it feels "slow"
-Then it decides to be slow in 1st and 2nd then fast in 3rd
-Literally 5 seconds later i boot it again to see any difference, it decides to be fast or slow in random gears
-The car has a f**ked clutch booster, its making the squeeky sound and is leaking air, could this contribute to the problem?
-I have checked my hand controller, at idle afm 1 is sitting at 0.1 and afm 2 is on 0.15 volts (actual numbers are afm1 89-94 afm2 1.06-8
-Under light load in neutral it gets closer to 0.2 difference and when i back off it goes to 0.27 difference
-Abd drops alot faster than afm 2, is that too much of an variable for those afms?
-The afm's are Z32
It sounds like a afm problem but i could be wrong.
Edited by Sedat
https://www.sau.com.au/forums/topic/341089-having-problems-with-my-r32-gtr/
Just tested the car underload and the results were
AFM 1: 4.19 volts
AFM 2: 3.88 - 3.98 volts
at idle
AFM 1: 0.91
AFM 2: 1.08
Is it normal for AFM 1 to be lower at idle and higher under load? And is that an acceptable variance?
The car has been running perfect today, no loss of power at all so i am stumped as to what the problem is. Any help would be appreciated and if this is in the wrong section can it be moved please
  T04GTR said:
silly question, but have you earthed the fuel pump? takes 5 mins to do and eliminates so anoying and potentialy destructive problems
Not sure, car was bought as is besides the tune i had done to it a month or so ago. Have had the car for a year and a half and this is the first time it has done something like this :D
