Having troubles with my gtr, here are the symptoms:
Power: 320awkw
-When under load in 1st and 2nd gear it feels normal (fast) but i put it into 3rd it feels "slow"
-Then it decides to be slow in 1st and 2nd then fast in 3rd
-Literally 5 seconds later i boot it again to see any difference, it decides to be fast or slow in random gears
-The car has a f**ked clutch booster, its making the squeeky sound and is leaking air, could this contribute to the problem?
-I have checked my hand controller, at idle afm 1 is sitting at 0.1 and afm 2 is on 0.15 volts (actual numbers are afm1 89-94 afm2 1.06-8
-Under light load in neutral it gets closer to 0.2 difference and when i back off it goes to 0.27 difference
-Abd drops alot faster than afm 2, is that too much of an variable for those afms?
-The afm's are Z32
It sounds like a afm problem but i could be wrong.
Edited by Sedat
https://www.sau.com.au/forums/topic/341089-having-problems-with-my-r32-gtr/
Just tested the car underload and the results were
AFM 1: 4.19 volts
AFM 2: 3.88 - 3.98 volts
at idle
AFM 1: 0.91
AFM 2: 1.08
Is it normal for AFM 1 to be lower at idle and higher under load? And is that an acceptable variance?
The car has been running perfect today, no loss of power at all so i am stumped as to what the problem is. Any help would be appreciated and if this is in the wrong section can it be moved please
silly question, but have you earthed the fuel pump? takes 5 mins to do and eliminates so anoying and potentialy destructive problems
Not sure, car was bought as is besides the tune i had done to it a month or so ago. Have had the car for a year and a half and this is the first time it has done something like this :D
