Hey guys, thought I would share my R33 GTST.
Engine: 25/30 Spool Rods, Wisco Pistons, Custom Grind Cams, You get the Idea..
Exhaust: 4 Inch Turbo Back
Suspension: Lowered Springs
Wheels: Crap 17's Will Change Soon
Modifications: Microtech,1600cc Injectors,42R,Twin 1/2 Inch Fuel Lines, Twin Pumps and a lot more.
Stereo Audio / Visual: Cd player.
Estimated Power: 722rwhp With Blown Turbo Gasket
https://www.sau.com.au/forums/topic/341110-my-r33/
hay buddy how r ya
very awesome build u have there.
just a couple of quick question as im doing a similar build myself atm
how does the 42r go in terms of coming on boost.
like when does it start to build and when is full boost achieved?
how does it go with traction?
what gearbox are u running?
thanks buddy
https://www.sau.com.au/forums/topic/341110-my-r33/#findComment-5510917
  • 3 weeks later...
Hey guys quick update, Got sick of green and decided to paint it. Getting there I only have 1 day off a week if that so doing it all in my spare time.
Here is some progress pics.
I shaved the aerial hole while I was @ it.
I am painting it blue will get pic of colour up soon. I mixed it at work very nice :D
https://www.sau.com.au/forums/topic/341110-my-r33/#findComment-5551141
  • 4 months later...
  • 4 months later...
  • 1 month later...
  • 1 month later...
  • 3 months later...
Sorry everyone been very slack :) Got the car out to QLD Power Play finally :) Few things still to do but had a great day!
Ill put few pics up.
Empty Bay =(
XR8 Buldge For A Different Look
Scott standing with my motor :) Thanks Gman @ Turbowerx Automotive
https://www.sau.com.au/forums/topic/341110-my-r33/#findComment-6243756
If anyone has the black plastic inserts for my front bar and want to sell please let me know 0432 238 529
Some one stole my whole front bar inc number plate so I was lucky enough to source another one and paint it quickly but no front inserts :(
https://www.sau.com.au/forums/topic/341110-my-r33/#findComment-6243761
    • That's awesome, well done! Love all these older Datsun / Nissans so rare now
    • As I said, there's trade offs to jamming EVERYTHING in. Timing, resources etc, being the huge ones. Calling out the factory ECU has nothing to do with it, as it doesn't do any form of fancy boost control. It's all open loop boost control. You mention the Haltech Nexus, that's effectively two separate devices jammed into one box. What you quote about it, is proof for that. So now you've lost flexibility as a product too...   A product designed to do one thing really well, will always beat other products doing multiple things. Also, I wouldn't knock COTS stuff, you'd be surprised how many things are using it, that you're probably totally in love with As for the SpaceX comment that we're working directly with them, it's about the type of stuff we're doing. We're doing design work, and breaking world firsts. If you can't understand that I have real world hands on experience, including in very modern tech, and actually understand this stuff, then to avoid useless debates where you just won't accept fact and experience, from here on, it seems you'd be be happy I (and possibly anyone with knowledge really) not reply to your questions, or input, no matter how much help you could be given to help you, or let you learn. It seems you're happy reading your data sheets, factory service manuals, and only want people to reinforce your thoughts and points of view.
    • I don't really understand because clearly it's possible. The factory ECU is running on like a 4 MHz 16-bit processor. Modern GDI ECUs have like 200 MHz superscalar cores with floating point units too. The Haltech Nexus has two 240 MHz CPU cores. The Elite 2500 is a single 80 MHz core. Surely 20x the compute means adding some PID boost control logic isn't that complicated. I'm not saying clock speed is everything, but the requirements to add boost control to a port injection 6 cylinder ECU are really not that difficult. More I/O, more interrupt handlers, more working memory, etc isn't that crazy to figure out. SpaceX if anything shows just how far you can get arguably doing things the "wrong" way, ie x86 COTS running C++ on Linux. That is about as far away from the "correct" architecture as it gets for a real time system, but it works anyways.
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
