Ive had 20's on my R34 coupe for 4 years with no issues, except i did have to shave off a small bit of metal on the upper control arms of the front suspension to stop the tyres from scrubbing. Car drives well and still handles great.
  • Replies 60
Umad? U jelly?
:P
can i grab that in english pls.
EDIT.. think i get it are you asking if im jelous? no sir far far far far from it.. think a billion times opposite and thats what i would be. if anything bigger than 18s ever get near my skyline ill drive it down to sims metal myself.
All in all big wheels will achieve nothing other than feeding some chinaman and his family for a day..so why not cut out the middle man and send your hard earned $$$ straight too world vision and do the world a favour
In the poorer areas of China, most families live on a budget of ~100 Chinese dollars (now only ~$15 AUD atm) per month, so those big bling wheels & China made tyres will not last the family for a day, it will last them at least a week or more...
So everyone should help out & start buying 20 & 22s wheels!
:P
Cool story bro!
Off topic , If the wheel starts scrubbing the mudguard a tad due to +25 spacers is there anyway to fix this.
Its only 1 small same area of the mud guard that gets scrubbed
Edit : car is GTR34 Stock wheels , Car is lowered ... =(
Edited by Longz
These ones I have for sale came off R34 GT-T.. it did require rolled guards and as you can see the tyres are a little stretched. Car has Tein coil overs. Was no big issues with scrubbing but some wiring in the drivers front guard needed to be tucked up a little bit out of the way to be on the safe side.
I don't see what's the fuzz about putting 20" on the 34 !!!!!!!! I put 21" on my RX8 in Need for Speed Underground
with out any problem and slammed it about 5 mm off the ground, the car didn't scrape and tyres didn't rub the
guard at all, and I bloody went faster than Porche and Ferrari,
What's the fuzz !
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
