Hey all
Have decided that i am going to strip my car and sell off the parts so get in quick.
Car is currently still together but will start taking her apart over the weekend
below is what i have
ITEM : GENUINE HKS 25/30 ( LESS THEN 3000KM ON TURBO, NO PLAY AT ALL )
ITEM : GENUINE HKS SERIES 2 DUMP ( LARGER WASTEGATE PIPE )
ITEM : XSPEED JAPAN STAINLESS LOW MOUNT EXHAUST MANIFOLD
ALL FITTINGS AND LINES
CONDITION : near new
THIS KIT MADE 270RWKW AND 840NM OF TORQUE ON MY BUILT RB24
AWESOME SETUP , INSTANT RESPONSE
PRICE - $2000.00 complete, $1500 for turbo- turbo lines and acuator, $300 hks series 2 dump, $500 for xspeed manifold
ITEM : Siemens 600cc injectors with HKS fuel rail
CONDITION : Near new , cost $1500 less then 500KM ago
PRICE : $ 800 complete
ITEM : Sard fuel regulator ( custom top secret sard special )
CONDITION : NEAR NEW
PRICE : $200
ITEM : Cusco coil overs for r32 ( will fit others as well )
CONDITION : great, no leaks
PRICE : $1000
ITEM : R33 GTR rims and tyres
CONDITION : OK, have a couple scrapes and rash marks
PRICE : $750
ITEM : Custom SPEED LAB front mount 600X330X125 ( BIG )
CONDITION : NEAR NEW, PIPING NOT INCLUDED
PRICE : $600
ITEM : Custom GTR plenum & throttle bodies for RB20 head
MUST HAVE FOR ANY ONE WITH A RB20!! ALOT OF HARD WORK WENT INTO THE MAKING OF THIS. SOUNDS AWESOME.
CONDITION : GREAT
PRICE : $1200
ITEM : Autronic SM-4 with custom RB loom, sensors and LED's
CONDITION : Next to brand new
CAN BE RE PROGRAMMED TO SUIT ANY APPLICATION, WAS TUNED AND AND MADE FOR ALL THE ABOVE ITEMS.
PRICE : $1900 ( sm4 alone is $2300 new )
ITEM : Kaaz 2 way diff with GTR cover plate for better cooling and more oil
CONDITION : GREAT
PRICE : $800
ITEM : R33 GTR V-SPEC front seats
CONDITION : Great, no marks or tears!
PRICE : $650.00 pair
ITEM : R32 GTST front seats
CONDITION : Good for age
PRICE : $100 pair
ITEM : HKS twin plate for RB20 ( may fit other )
PRICE : $1250
ITEM : N1 R32 head lights ( stand out from the crowed )
CONDITION : Great
PRICE : $400 pair
ITEM : R32 Rear PODS in white
CONDITION : OK
PRICE : $120 pair
ITEM : R32 GTR brakes with sloted rotors and top secret pads
CONDITION : great
PRICE : $600 front and rear
ITEM : Front / reat r32 strut bars
CONDITION : Good
PRICE : $150 PAIR
ITEM : CUSCO r32 brake master stopper
PRICE : $100
ITEM : BUILT RB24
ENGINE HAS JUST BEEN RUN IN WITH A HKS 25/30 AND IS A ANIMAL!! MADE 270RWKW & 840NM TORQUE !!!! DYNO PRINTOUT PROVEN
BOTTOM END IS BRAND NEW
SPEEDLAB CUSTOM RB24 ( CUSTOM MACHINED R34 GTR CRANK )
GRUB SCREWED CRANK
LINISHED CRANK
EAGLE RODS
TOMEI PISTONS
ARP RACE SERIES STUDS
TOMEI RINGS
PISTONS HAVE BEEN TEFLON COATED
FRESH LINE BORE AND HONE
ACL RACE SERIES MAIN AND ROD BEARINGS
CUSTOM SUMP BAFFLES WITH TRAP DOORS
CUSTOM 9L SUMP
N1 OIL PUMP
N1 WATER PUMP
CUSTOM HKS 1.2MM HEAD GASKET
THIS BOTTOM END HAS BEEN MADE TO STAND BIG HP AND BIG RPM. ONLY TOP QUALITY PARTS FROM JAPAN, USED AND THE BEST MACHINING HAS BEEN DONE.
THIS BOTTOM END HAS COST ME BIG $$$
ENGINE ( HEAD )
FULL RACE PORTING
JUN 272 – 10.8mm LIFT ( BIG ) INLET AND EXHAUST CAMS
JJR ADJUSTABLE CAM GEARS
TOMEI SPRINGS
TOMEI BUCKETS
GREDDY TIMING BELT
CUSTOM OIL DRAIN MACHINED FROM THE BACK OF THE HEAD TO SUMP.
CUSTOM PAINTED ENGINE COVERS
THIS HEAD HAS HAD OVER $7K SPENT ON IT IN MACHINING AND PARTS FROM JAPAN.
THIS WOULD MAKE A GREAT STREET ENGINE OR TRACK ENGINE.
PRICE : $7500
ITEM : R32 four door shell
SILVER, BODY IS A LITTLE RUFF BUT STILL PRITTY GOOD CONSIDERING ITS OVER 20 YEARS OLD
1989 MODEL
HYDROLIC HAND BRAKE
ARC FRONT CASTER ARMS
CUSCO UPPER FRONT ARMS
CUSCO REAR UPPER ARMS
CEFIRO ENGINE X MEMBER ( ENGINE SITS LOWER THE STANDARD X MEMBER )
90% OF INTERIOR STILL THERE
99% OF ALL PANELS
BOSCH 044 AND CUSTOM SWIRL POT
D1 DEEP DISH STEERING WHEEL
HEAPS OF OTHER BITS AND PEICES
MINUS THE BELOW
NO ENGINE OR ENGINE RELATED PARTS
NO GEAR BOX
NO DIFF
NO ECU OR WIRING
NO SUSPENSION
NO WHEELS
NO HEAD LIGHTS
COUPLE OTHER SMALL BITS MISSING
CONDITION : OK for age and comes with alot of parts and listed parts not with car
$2200.00 INCLUDING REGO!
OR TAKE THE COMPLETE CAR AND ALL PARTS $16K !!!
LOCATION : ALL ITEMS ARE IN ADELAIDE, POSTAGE AT BUYERS EXPENSE
CONTACT : PM ME
PICTURES : CAN MMS PEOPLE PICS
  • Replies 52
Rims back up for sale due to sale falling thru
gixxer07, PM me your number and ill mms you pics, HKS 25/30 on a sr20 would be pritty good , nice and responsive with a decent power band
hey mate, my mate might be interested in the 33 gtr rims...still got that for sale? if do where are you located and could you please pm me some pics of it? thnx...
Are these high or low impedance?
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
    • Well, no. It's an 023, which is pretty similar to an 040. Although it is hard to tell from the specs, as given.
    • Hmm. Maybe the (other thing I forgot about!) Haltech removes at least some, if not all, of the problem I described. I guess there is still the possibility of getting it wrong if the AC is set up/wired up for the Haltech as if it was in an R34 (simply because it's on a Neo), and that's playing foul with the R32 AC computer.
