As long as there is plenty of turbo flow and everything else to back it up, more than happy to consider it. If you like, pm me the details of the engine mod's and we can go from there.
I want to get results at different boost levels to see the overall impact. I also have an egt kit I would like to install to get even more data to back things up one way or another.
Lol funny you should mention that, I just pulled one apart an hour ago. First time I noticed them too. I figured much the same; an attempt to direct air towards the runners rather then letting it all gush straight to number 6. I would have thought they would need to be abit longer (protrude in more) to have enough of a difference.
exactly the reason why they have done it. there are some cad simulation programs results which show this would be beneficial.
as for all the air being directed to no6....this is not necessarily true considering cylinders fire at different times and the air is used only when valves are open. you will find that the rear cylinders, 5 & 6, of the gtr plenum actually flows less than the 1 & 2.
Oh good. The reason why i asked is becasue sometimes people just ask it because they think its fancy and have read it somewhere else....and I also wanted to see who could do it for me so I could compare it to flowbench figures...unfortunately your in QLD.
So that would answer your questions, no I don't but would like to find somene local who could do it for me and show me how its done...so if there is anyone out there who can, please pm me.
Interesting about the flow. I thought the major belief was that 5 and 6 flowed abit more (or atleast received air first and more of it) and so always ran a fraction leaner as a result, hence why alot of tuning shops richen 6 up by 1.5% and 5 by 1% or something like that.
Funnily enough I thought all forward facing plenums were susceptible to that problem by that same reasoning.
Did you test this by egts on each exhaust runner with matched injectors? or some kind of flow test on the manifold itself?
that is far from the truth!!!! another one of those internet created misconceptions....and there are plenty more out there
this was tested on a flow bench....EGT testing is coming with the test car
as for rb20 info, watch this space when i get some time after the rb25 testing
i actually need someone to draw them up for me to do the cfd
from reports cfd results are actually very similar to flow test results when the same environment is used, meaning real world vs what is simulated
Edited by ISL33P
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
    • Just putting it out there, that's a decent list. You would be better off *not* doing *any* of that and buying someone else's modded car. Like mine. Or anybody else's. Yes it's lotto dependent and all this and that but that 70K (remember, double your guesses) could go elsewhere. Keep it stock, save your money, go lowball @Dose Pipe Sutututu :p
    • Does not mean what you think it means. The continual rising coefficient is the coefficient of friction that continues to rise with increasing temperature. Not "rising during a single stop", except inasmuch as the brakes should get hotter during a single stop. The RR would not be the best choice for a streeter. Yeah....no it's not. JAX would rummage around in the "shit pads we use for all shitboxen that come in here" and install those.
    • @Kinkstaah I've got my list.. but most of them is to do if I ever win the lotto
