INASNT, The stock manifold is far from being anything special but it will do what I want it to do. Unlike the stock turbo, cooler or exhaust. Well even my 3" exhaust may prove to be a little on the small side up around 300kw at the rears. But in all honesty on the street I doubt it will be running that much power as I'm going to have the power reduced until it is drivable. No good have wheel spin to the point where you can't control it. That is one of the reasons why I went the larger motor, I'm hoping the power delivery will be smoother & tend not to snap the tyres in to a cloud of smoke or at least be more controllable. I think the RB20t has got me worried to much as the RB20t is a on or off motor. Its either nothing or everything.
If I do run in to problems with the manifold, she will do for a while until I get some more money together for a low mount manifold. Something that can be hidden or at least looks stockish.
I guess my point is, why throw it out the window before I see how it goes especially when the bottom end has cost me 4k and the top end has cost me close to 2k.
If only I bought a 33 to start off with it would have been much cheaper to get up to the power level I am after. Well it would have saved me 2k for both the head purchase & work/rebuild.
Why do you feel so strong about the custom exhaust manifold? What are your experiences?
Most people I have spoke to have said yer it does spool a little earlier and make slightly more top end and overall power but not really that much when you consider the negatives.
  • Replies 69
Joel,
Yeah same clutch mate. Xtreme 9 puck ceramic cushion button. We tested my pressure plate & it was 1095kg from memory. I've been really happy with mine so far, very easy to drive in traffic & hasn't even looked like slipping yet.
heres another pic of the pistons for anyone interested.
At this point i'd like to say a large THANKYOU to Joel for organizing this engine for us:)
Without his helpful advice I would be driving a rb20 still :) and wondering where all the power is :)
The price has blown out a bit though.
What makes me feel better is telling my self that the RB20t really isn't a good streetable engine as its power delivery when changing turbo's from std is too laggy. :) Well it works for me.
I forgot to add.
Thats what I keep telling the other half so she doesn't question why i am spending so much :) Even though she gets a little stressed with the lack of low down punch or should i say no low down punch.
A performance engine rebuild price blow out? That doesn't happen very often :)
yer it wasnt like it wasn't expected though. If we stuck to the "original" plan the motor would have only cost $1875 ish. :)
remember those days Joel?:) Ahh yer - it'll be finished by october :D
New oil pump throws things right up the sh.it worth 1/5 the motor :)
Speak to GTR-BEN as he is also doing the RB30 thing with his GTR.
There is also a RB30DET thread 'sticky' in the forced induction performance section of SAU. Ask the question there you may get a few more answers.
Looks like I'll be seeing how the R32's rb20det tows a vn v6 blown up commodore within the hour. I've dropped boost back a little from 17 as it is pretty hot and dropped the timing from 22 back to 15. Its going to be loaded up going up flagstaff hill road.
lol.. the vn shat a coil pack.. drove it home no towing.. :) I was looking forward to boosting as well.. :P
I've done it once before with a proper tow rope.. Came on to boost in first start to spin the wheels up. :)
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
